Question about RCA Televison & Video
If you are unable to receive channel 526 or 54 on your RCA HDMI TV and the picture goes pixels or freezes, it may be caused by a few different issues:
It's important to note that in some cases, the channels you're trying to watch may be experiencing technical difficulties, or the channel is not available in your area.
Posted on Jan 14, 2023
SOURCE: digital tv
Is this a HD channel? This is usually caused by a hiccup in the streaming of HD from the cable/sat company. How long has this been happening?
Posted on Mar 07, 2008
SOURCE: How do I program my RCA LED48G45RQ HDMI to digital channels
Several things to check. First go in the menu where u are doing the channel scan and see if there is a separate line that says digital and if so select it so it can add those channels. Next look also on the remote and see if there is a button that says ANT or Input and press it to see if selects the digital side. Next see how u are hooking up the set from either cable, SAT, Antenna, etc, and are u going thru the antenna connection/the screw on cable input. Cause if going thru hdmi or any other input will not allow u to scan channels. Next the tv may not have a digital tuner in which some new sets don't, look in owners manual and read on channel programming and it should tell u. Maybe something here will help.
Posted on Dec 09, 2014
