I was involved in an accident last night and the car was driveable but had to be towed. Engine turned over but it wouldn't start. The officer said it was probably due to the kill switch being actiivated.
SOURCE: The Volvo S40, 2,4i, 2007, fuel cut off switch
look in the trunk... either it has side panels that can be removed... or you will see a hole in the side of the lining with a sticker that points out where it is.
Robert
Please take a moment to rate this solution thanks
SOURCE: kill switch automatically activates
It is a problem most likely with the key sensor for the lock out.
SOURCE: 2005 Chrysler town & country touring won't turn over.
Sounds like you need a starter, or you have a loose wire somewhere under the hood.
SOURCE: service engine soon light on in 2004 buick
oh thats the change oil light expect it every 3500 to 4500 miles they glow.. you can usually reset it by holding down the trip button with the car off and then turn the key to the II position where everything lights up
so read me >>>>>
Buick Rainier 2004-06, Buick Rendezvous 2002-05 w/o (DIC) Driver Information Center
Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three time in five seconds. If the CHANGE OIL SOON’ indicator flashes two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHANGE OIL SOON indicator comes on and stays on for five seconds, repeat the procedure.
Buick Rainier 2004-05 wI (DIC) Driver Information Center
The DIC display is located on the instrument panel cluster above the steering wheel. The DIG buttons are located on the steering wheel. Press button with the gas pump symbol to display engine oil life. Press button with the arrow symbol to reset engine oil life display.
Buick Rendezvous 2002-06 wI (DIC) Driver Information Center
To reset Service Reminder Indicator, turn ignition on with engine not running. Press the MODE button until DIC reads oil life left hold SET to reset. Press and hold the SET button until 100% is displayed. You will hear three chimes and the change oil message will go out. If the CHANGE ENGINE OIL’ message comes back on when the vehicle is started, the engine oil life system has not reset. Repeat the procedure.
SOURCE: BMW 325xi; 160k; check engine light on-->next day, wont start!
The check engine light is a warning to let you know something needs your attention to be repaired I would try getting a jump. Could be a bad battery. Lets get the battery charged and tested. Cold weather will stop your car from starting if you have a weak battery. You dont need to tow the car just take the battery to Autozone or Walmart to be charged and tested for cca...cold cranking amps
