Is this a new tstat? How about trying cooling with fan in on position , what happens? What is the model number of your indoor unit please.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: Goodman Furnace/AC unit not working
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
SOURCE: problem with my AC unit
Hi Phillip,
Check your thermostat wires to see if you have any of them which are bare and touching. If any are touching separate them and tape em up and try unit again. You have a direst short in your cooling portion of the unit.
SOURCE: I have a goodman furnace and ac unit the fan and
Look at the contactor on the condensing unit, remove the low voltage wires to the contactor and turn on the system. If the low voltage fuse doesn't blow, replace the contactor.
SOURCE: 2008 Nissan Rogue blower continues blowing only on
Did you ever get this problem fixed? It just happened to my Nissan Rogue 2008. Would like to know how to fix it. Thanks!
