Question about Juicers
Jc-6 vitamin juicer. How to remove grater to clean
Posted by Robin Sawyer on
Marvin
    Top Expert:
  • 85,239 Answers
Posted on May 25, 2018
2 Related Answers
Juice_Man
SOURCE: how to remove strainer/grater from vitamin bar juicer
I am assuming your juicer is the same as mine. The JC-6 White with "Vitamin Bar" and a carrot on the front.
There is most likely a tool that you insert in the back slot, but since I don't know of one, I had to get creative.
First unplug the juicer and undo the side locks, remove the clear cap. Look in the back, there is a 2-inch wide slot where you can see the motor and locking mechanism.
Take a butter knife and hold the mechanism in place. Use your other hand or have a partner spin the mesh/bladed bowl counter-clockwise.
With just some effort and a small "pop" noise, the piece should be free.
I searched forever for a solution, I hope someone with a similar plight finds this helpful.
Posted on Aug 07, 2011
Anonymous
  • 7 Answers
SOURCE: How to clean the Jack LaLane Juicer?
the blade can be removed possibly with your hands, if you can manage to turn it, if not then find something that will fit into those little holes of the blade to turn it, and then take it apart, but remember in what order. to put it together: the grey thing with the spout attached goes on first, then the orange basket, then the blade, but don't turn it too tight, just look for the indicator marks and line them up with the arrows, then the black lid, and then the pulp basket.make sure that the black lid in the back, goes INTO the pulp collector, it is not very far, but if it is not done like this, then your machine will not work. then you raise and lock the bar into place and put the pusher into the feeding tube. hope that helps.
Posted on Jun 30, 2009
How do I remove the grater/filter from juice collector to clean it? Also the juice collector from the drive shaft? Thanks
You have to lift off the juice collector (the black part around the grater)-you have to use a little force-then you'll be able to take out the grater.
Jan 10, 2011 | Maximatic EJX9700 Juicer
How to remove strainer/grater from vitamin bar juicer
Mar 15, 2010 | Salton Juicers
How do you take the grater off the juiceman2 the part that the fruits and vegetables get grated. Thank you
how do you take the grater off the juiceman2 the part that the fruits and vegetables get grated.
Dec 12, 2009 | Salton JM411 Juiceman II Elite Juicer
The plastic screw, which the grater is screwed onto (looks like part of the motor) is broken.
I had the juicer for exactly two weeks and the same piece broke. The little plastic part in which the blade screws onto. Called the company and they were actually no help at all. Please don't waste your money!
Nov 14, 2009 | Jack Lalanne Power Juicer 250 Watts
Breville je2 (anthony worrell juicer) lost the blade!! slicer!!! thing
Am currently looking for a spare part for mine. If I fail to find it, u can have my grater bit!!
May 02, 2008 | Breville JE3 Juicer
How do u wash this?
if you have a jack lalanne it comes with an orange handle that fits into the sharp cutter and you twist it to tighten/loosen the blade. hope this helps
Dec 04, 2007 | Juicers
OPENING the JC-250 Juice Extractor
Hey, you probably have figured it out! I just got a juicer without a manual and couldn't find a way to dismantle for cleaning but I got it!!!!!!!!! Just put it upside down and twist and turn. Everything will fall off ( cutter and container). I'm so happy to help!!
Jan 22, 2007 | Brentwood JC-250 Juice Extractor 350 Watts
Juicers Logo
426 people viewed this question
Top Juicers Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Juicer Expert? Answer questions, earn points and help others
