Question about Samsung YP-U3 MP3 Player
Software - firmware
One of the drop-down (Portable device) from the menu bar is inactive. what have we done wrong? All others are active. This is my mom's mp 3, and I actually don't even know how to use them. Her system is completely in Korean, and she is having a hard time installing it, and I want to help.
thanks!!!
Posted by geminielf on
  • Anonymous Dec 14, 2007
    YH-820 not play mp3
ThaMp3Doctor
  • 8,597 Answers
Read your manual to find out how to change language
Firmware Upgrade:
http://www.samsung.com/us/support/download/supportDown.do?group=audiovideo&type=mp3players&subtype=flashmemory&model_nm=YP-U3JQPY&language=&cate_type=all&dType=D&mType=FM&vType=L&prd_ia_cd=03040200&disp_nm=YP-U3JQPY
Posted on Jul 06, 2008
WHAT SOFTWARE WILL I NEED TO HTC WILDFIRE A3333 TO MY PC FOR INTERNET?
1. Touch Menu.
2. Touch Settings.
3. Touch Wireless & networks.
4. Touch Portable Wi-Fi hotspot settings.
5. Delete the existing text and enter a name for your hotspot.
6. Scroll down to Password.
7. Delete the existing text and enter a password for your hotspot.
8. Touch Back.
9. Touch Portable Wi-Fi Hotspot.
10. Touch OK.
11. The portable Wi-Fi hotspot is now active. Other devices can now connect with the Wildfire.
Apr 24, 2014 | liion 4400mah Li-ion Battery For Mecer...
Bizhub 211 double sided printing inactive
It was the same problem. To enable drop down menu open "Device Option" tab where you will see list:
Duplex Non Instaled
Tray2 Not Installed
Tray3 Not Installed
Just double click on "Duplex Not Installed" and it will changes on "Installed" and Double sides drop down menu become active.
Jan 20, 2012 | Konica Minolta bizhub Office Equipment &...
I have purchased a new computer and want to install my rent-right. Please give me step by step instructions on what to do
To install RentRight and transfer you data onto a new computer?
Answer :
Follow this link to download and install RentRight v3 on your NEW computer: http://www.rent-right.com/support/UpdateVer3FirstTime.html
If you are not using the Internet, you will need to order a CD with the full version of RentRight to install into your new computer.
Follow this link to download and Update to the latest version of RentRight v3 on your OLD computer: http://www.rent-right.com/support/UpdateVer3.html
DO NOT change the installation directory folder. When asked if you want to write over the existing folder, reply, YES. Respond to the prompts to complete the installation.
When done, open RentRight on your old computer, go to File on the menu bar and choose BACK UP to back up your data, and save it to your Desktop.
TO BACKUP YOUR DATA:
Insert a portable storage device, such as a blank CD or USB memory stick, into your computer.
We recommend that you do not us a 3 1/2 floppy disk, because it is not reliable, and may not have a
large enough storage capacity to hold your backup.
In RentRight, click on File from your Menu bar
Select Backup
Click the Backup button
The Back Up window will open:
Use the "Save In" drop-down menu to navigate to the desired location, such as your Desktop
DO NOT BACK UP DIRECTLY TO YOUR PORTABLE STORAGE DEVICE
Click on the Save button
Copy the backup that you just created, rrbackv3.zip, from your saved location to the portable storage device you inserted into your computer.
Copy and Paste the Backup Database you just created, from your Desktop to a portable storage device,
such as a cd or flash drive.
Take the portable storage device containing your backup from your old computer to your new computer, and Copy and Paste the Backup Database from your portable storage device to your Desktop.
Open RentRight on your new computer, go to File, and RESTORE your data.
TO RESTORE YOUR DATA:
1. Locate your rrbackv3.zip file
2. Right-Click on your rrbackv3.zip
3. Select 'Extract All' from the drop-down menu
4. Follow the Extraction Wizard prompts. This will create a Folder with the name rrbackv3. In this folder will be a file called 'aptment.mdb'. You may not see the .mdb file extension if you do not have this preference set. This aptment.mdb file is your Backup Database, and is the one you want to restore in RentRight.
5. Start RentRight.
6. Select File from the Menu Bar.
7. Select Restore.
8. Cancel the "insert a disk into drive A" message, unless you are using a 3 1/2 inch floppy disk. If so, insert the disk.
9. Click on the drop-down arrow in the 'Files of type' field, and select 'All Files'
10. Click on the drop-down arrow in the 'Look in' field, navigate to the aptment.mdb you just extracted, and click on it.
11. Click the Restore button
KEEP IN MIND THAT YOU CANNOT BACKUP OR RESTORE DIRECTLY BETWEEN RENTRIGHT AND A PORTABLE STORAGE DEVICE.
You must backup your data to your desktop, and then copy that file from your desktop to your portable storage device, such as a disc or flash drive. The same applies for restoring from a portable storage device: you must copy that backup from your portable storage device to your desktop, and restore your data from the file copied on your desktop.
Now you need to move your license to the new computer.
You must first de-activate the license from the old computer. Go to Help/RentRight Sales on the old computer. Follow the prompts about moving from one computer to another. Next, choose the option to "Activate over the Phone". Contact us by phone at 800.964.8065 x2826, or email and provide us with the Entry Codes and Computer ID numbers for both the old and new computer. After deactivating the license on your old computer, we will give you a different activation code for the new computer.
Aug 22, 2011 | RentRight Property Management Software...
I am running Windows 7 and some how I lost my toolbars, File, Edit etc
To add a toolbar, click Tools, then Toolbars from the Command bar or right-click on the Command bar to see a list of toolbar options. You can activate or deactivate a number of Internet Explorer toolbars from this menu option. You can even Lock the Toolbars to make Internet Explorer show the same toolbars each time you use the browser.
To add or remove Add-ons, click Tools from the Command bar and select Manage Add-ons from the drop-down menu. From this menu you can view and manage a list of different Add-on Types you've got installed in the browser. To add more, click on the Find more providers... option at the bottom of the window. To delete an Add-on, highlight the one you wish to remove and select Remove, or select Disable if you wish to leave it installed but make it inactive.
Nov 08, 2010 | Compaq Computers & Internet
Website toolbar is not showing up
To add a toolbar, click Tools, then Toolbars from the Command bar or right-click on the Command bar to see a list of toolbar options. You can activate or deactivate a number of Internet Explorer toolbars from this menu option. You can even Lock the Toolbars to make Internet Explorer 8 show the same toolbars each time you use the browser.
Oct 17, 2010 | Microsoft Internet Explorer 8
Delete music from pd-6070
The MyMusix device software is buggy and prone to break downs from time to time. Reformatting the device usually fixes these problems. The best way to reformat is to use the manufactures firmware update process.
Go to the MyMusix.com website and download and install the firmware upgrade for the PD-6070 player using the download drop-down menu.
Back up all of the songs on your player to your computer hard drive.
Carefully read (or better yet print for future reference) the PD-6070 FAQ instructions for running the firmware upgrade, especially the drop down to select the US version of the firmware.
Run the firmware upgrade. It will reformat your device and restore it to it's original capacity.
May 06, 2008 | MyMusix PD-6070 MP3 Player
Display property settings
Hello Phil 65
Happy Holidays
well, the best bet for you, is uninstall the Driver for your video card, from device manager , and ADD/Remove programs, your other features for the particular video card. ONLY.
then go ahead and restart your PC, reinstall drivers according, and have your CD for video drivers and settings program.
that should restore your video , ....or use the Windows Restore point feature to a date all work fine.
good luck
Dec 05, 2007 | Sony VAIO PCV-J120 PC Desktop
Problem
Install and run the Device Manager software from the product CD.
Use the Restore option to format the device and reload the firmware.
This should fix the "Connect to PC" problem.
To download tracks you need to use the Music Match software on the product CD.
Make sure that the software recognises the player as "GoGear" and not "Removable Drive E:" etc
If the software shows the device as removable drive then go into the Music Match options menu and click the drop down menu, select GoGear and click apply.
Dec 03, 2007 | Philips PSS110/17 MP3 Player
Firmware question
First report me if there is a blank white screen.
If it is there then I will be sincere to you on this part. This is a VERY BAD thing to do. Why? Because in Korea there are thousands of OEM MP4 factories and each of them has modified the original MP4 schematics to bring improvements. This way now on the market, even if two players look the same, the board type may be different, so the firmware from one player will not work
to another. Anyway there is a chance to bring it to life.Install back the firmware provided within the cd if the cd's gone throw your mp3 its a useless device.
you should uninstall your current utilities and install 4.15. Here's a step by step guide that will help you flash your player:
– Connect your player to the PC via the USB cable
– Turn it on
– Wait until it is detected by the PC
– Start MP3 Player Upgrade Tool
Press “Select new firmware file”.
Now navigate to the firmwares,choose one of them and press “Open”
Nov 27, 2007 | Samsung YP-U3 MP3 Player
Samsung YP-U3 MP3 Player Logo
101 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
