Question about LG Computers & Internet
The GCC-5241P should get any available drivers from Windows Update's Plug and Play option, if you have Windows Update set to retrieve device drivers. The only drivers supplied with the external drive were for Window 98 SE.
Looking at the online pictures of the GCC-5241P, the drive used a serial to USB adapter. If you have connected the drive to your computer, go to the Device Manager. (Right click on the Start button and look for the appropriate line or left click and type the phrase). Look in the appropriate sections (Ports, Human Interface Devices and Universal Serial Bus) for a driver with an exclamation point in a yellow triangle. Double click on this item and check the various tabs to get the details that Windows used to identify the device. This might be a Prolific USB to UART/Serial/Printer device. If so, you need to know which chip and the version. A common Prolific serial to USB is the PL2303. The drivers for this are available here: http://www.prolific.com.tw/US/ShowProduct.aspx?p_id=225&pcid=41 . Depending on the version, this driver may not work. If you have a different device, try Google to find any specific drivers.
I hope this helps.
(I have several devices around that used the Prolific chipset. Unfortunately the oldest one, which was Windows 2000 and XP compatible at release, is not supported under Windows 10. Some other units still work.)
Posted on May 24, 2018
SOURCE: USB external hard drive driver
If you go into Computer Management and go to Storage > Disk Management. You'll see the partition there. Right click on it and assign it a drive letter. You will be able to access it from there.
Posted on Jan 30, 2009
SOURCE: my LG CD-RW/DVD drive Model:GCC-H23N cannot read
Make sure (ide) if the jumpers are set correctly ie master - slave - cable select
Some time you need the BIOS to detect the drive and it's position like secondary drive O set for AUTO
Then if that is good, go to LG's site and look for the latest Firmware for your model under support-download and drivers
And finally is it compatible with Vista..or what Operating System you are using.
And finally get a laser lens cleaner and clean the player's lens. It looks like a cd with an eyelashes glue on it. kennsington makes them and several other companies.
Barring all that a combo drive like your can be replace for $15-$20 pending where you shop.
I do like the LG brand...don't like Lite-On but hey that is just me.
hope this helps...please leave a rating. thanks
Posted on May 07, 2009
SOURCE: My LG combo drive HL-DT-ST RW/DVD GCC-H23Ndoes not
The lens for reading dvd is busted and needs to be replaced that is why it no longer read dvd.
Posted on Oct 31, 2009
SOURCE: I need the drive for my driver external super
you can go online and download the driver package. go to lg and click on drivers usually for free...
Posted on Nov 08, 2009
SOURCE: dont have drivers for model gcc-4320b cd-rw /
Check with the vendor/dealer who supplied the product. Also check and download drivers from hte vendor site.
Hope this gives you the information you need
Posted on Dec 16, 2009
