Question about Motorola Mobility RAZR V3
Motorola Razr V3 Screen looks like broken glass on inside :-/
Okay so i dropped my phone from my hand to the grass and the battery fell out. There is no scratches on the phone at all and there is no damage to the battery at all. Whenever I open my phone, the screen looks like broken glass. You can see the top right corner of the screen and thats it. There is no disfuntional keys at all and everything works, its just that on a white background, there is black lines that look like broken glass and i cant see any of my messages or anything that I do. There is also nothing wrong with the camera because if i press the camera button and close the phone then i can still take pictures. I paid a lot of money for this phone so help would be appreciated!! Thanks!
Posted by pennypickles on
  • 1 more comment
  • Anonymous Nov 25, 2007
    my phone fell to the ground on water
  • pennypickles Nov 25, 2007
    your looks like mine too?
  • pennypickles Nov 26, 2007
    oh okay so do you have any idea how much thats going to be?
Anonymous
  • 31 Answers
If the black lines u see across the screen looks like leaking ink, then it probly is, suggest u get a replace lcd for your phone
Posted on Nov 26, 2007
I dropped my phone on my apartment floor it was a motorola razor and when i dropped it the back and the battery fell out i picked it up and put the battery and back on the phone again and when i turned it...
Improve the Fixya.com experience for everyone by voting!
In my humble opinion, you have two inexpensive choices:
  1. Sign onto eBay and type in the following: Motorola V3 Razr original LCD display screen + tools and you can fix it yourself for less than $10.00.
  2. The second option is to buy a used phone for about $20.00 delivered, if you're lucky.
All the best,
Ben
Jul 15, 2011 | Motorola Mobility RAZR V3
Something under screen looks like lint or something . took it to at&t where i bought it . they said they couldn't fix it. the little specs make the screen look dirty
THE INSIDE SCREEN ON THE V3 IS ACTUALLY MADE OF A SOFT FLEXIBLE PLASTIC. YOU CAN REMOVE THE GLASS WITH SOMETHING AS SMALL AS A FINGERNAIL. BLOW IT OUT AND STICK IT BACK ON.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_156682b88afabb53
Dec 05, 2009 | Motorola Mobility RAZR V3
Motorola razr v3
the phone need to be flash to correct this issue, so take the phone to a mobile service center to correct this...
Oct 25, 2008 | Motorola Mobility RAZR V3
Motorola V3xx Razr Front LCD Screen Glass Repair
Your best bet would be to take it to your cellphone company and have them fix it for you.
Jul 03, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Blank screen
this happens either when u r razr was dropped or have gotten wet...If it fell u need to remove the four screws on the screen and pry the cover off with a possibly thin knife.The flex cable is located at the top left hand side of the screen. you need to take this off and reseat it again.try powering on the phone before u close it back again to ensure that it works.If this doesn't work either your screen or flex cable is gone, then u need to check a phone repair shop.you need either a t6 or a t4 screw driver set to remove the four screws located under the the 4 rubber fillers on the inner screen.
sam !
Feb 19, 2008 | Motorola Mobility RAZR V3
How to replace broken front glass on razr v3
If this isn't something you have tried before, I would HIGHLY recommend you take the phone and the part to a repair shop. This is a difficult procedure that does require special screwdrivers.
A repair shop will not charge you much for this at all, especially with the part in hand.
Dec 02, 2007 | Motorola Mobility RAZR V3
Dropped it and screen went blank
take the phone and have them replaced the lcd or flexcable
Aug 26, 2007 | Motorola Mobility RAZR V3
HELP BROKEN SCREEN
Hi try this ebay site. http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&ih=014&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=330069443591&rd=1&rd=1 Motorola V3 Razr Front LCD Screen + Len Cover Glass
Jan 06, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
257 people viewed this question
Top Motorola Mobility Cell Phones Experts
Vernon Taylor
Jeff
Harrie
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
