Question about Hisense Televison & Video
I have a Hisense Roku tv 32' (maybe a smart TV not sure )I want to connect my DVD recorder it has no HDMI ) to mytv how can I do this
Posted by christina Barnes on
john h
    Top Expert:
  • Hisense Master
  • 23,401 Answers
Buy an adapter
Posted on May 24, 2018
5 Related Answers
Anonymous
SOURCE: sa-dx1040 dvd optical input works, tv and cd do not.
You have to manually select digital input on the receiver.
Posted on Aug 30, 2008
Anonymous
SOURCE: Have connect dvd recorder to panasonic tv with
set all setting back to original state, disconnected all cables, re-connected and did setup again and all is well
Posted on Dec 07, 2009
Tashi Wanglay
SOURCE: DVD recorder will not pick up digital channels from TV
Our DVD recorder DMR-EH57 is recording but not able to show its video
recording to the LCD what is the problem.
Posted on Jul 02, 2012
ray gallant
  • 67943 Answers
SOURCE: HOW DO I CONNECT A LED SMART TV TO THE DVD RECORDER
use the RCA connector on the TV also
Posted on Jan 29, 2015
Jay Plesset
  • 2942 Answers
SOURCE: how do I connect a laptop to my hisense 32" smart led tv?
If both your laptop and TV had "HDMI" plugs, that's the easiest way to connect them. Otherwise, you will need to connect the video separately from the audio...
Posted on Feb 03, 2015
I have a HX32N2176h Hisense 32" LED tv will this TV handle and display HD when connected to a Laptop or Android Box with HDMI Cable?
The Hisense HX32N2176H will display an HD signal of 1366x720 with the HDMI input. (Any resolution above 480 (lines of pixels) is considered HD.) However, this isn't a full-HD (1080) capable TV. See https://www.hificorp.co.za/hisense-32in-81cm-hdr-led-tv-hx32n2176 for the specifications. Click on the Technical Details tab.
I hope this helps.
Apr 25, 2018 | Hisense Televison & Video
Codes to upgrade hisense40h3e to a smart tv
There is no code to turn the Hisense 40H3E into a smart TV. This TV doesn't have the network LAN or WI-FI hardware or software. You can only add network streaming by connecting a streaming stick (Roku, Fire, etc.), streaming box (similar items) or use a computer. Most streaming devices connect to the HDMI port; you may need an HDMI switch to share the TV with multiple devices.
Note: the USB port on this TV may not supply sufficient power for some streaming devices. You may need to connect them to an USB power supply to a standard outlet.
I hope this helps.
(the 40H3E does support viewing files from a USB flash drive - see the manual for the list. I found the manual on Manuals Lib here: https://www.manualslib.com/manual/1053975/Hisense-40h3e.html . )
Feb 18, 2018 | Televison & Video
I have a hisense tv 32” how do I connect to wireless wifi
This would depend on the model and whether it was a SMART TV.
The internet connection is via a LAN cable or via your satellite or cable box to your Home Network. Your smartphone connect to wifi and via that to the television.
Feb 05, 2018 | Hisense Televison & Video
OH. I have a DVD player/VCR Recorder. I have Cable TV. How do I connect DVD player/VCR recorder to Samsung Smart TV?
Unless your DVD/VCR is Upconverted to use HDMI, then you would use either the RED/GREEN/BLUE + Red /White leads to your TV and then use the TV remote to select whichever your TV names that input. If it is Upconverted, then simply plug the HDMI cable into a spare HDMI input.
Oct 06, 2016 | Panasonic Original Pansonic Tv Vcr Dvd...
How do i connect a smart tv that has hdmi to rca cables
Utilize the MiFine AV. This is a great product I have used many times located here or anywhere you can find it. I have only used this brand as many other reviews have stated they have problems with the cheap ones from China.
Mifine AV to HDMI HD Video Audio Converter 720p 1080p Mini 3RCA Composite CVBS to HDMI Switcher Portable AV2HDMI Adapter for TV/PC/PS2/PS3/PSX/Blue-Ray DVD
I purchased one for about $30 USD and you can use if for any device that has RCA cables such as a video recorder, VHS player, Wii, etc
Best Wishes,
Joe
I’m happy to help further over the phone at https://www.6ya.com/expert/mark_7bbaa7a1174e0903
Aug 25, 2016 | Hisense 55 2160p LED Ultra HDTV Class 4K...
How do I connect a laptop to my hisense 32" smart led tv?
Feb 03, 2015 | Hisense Televison & Video
How to hook up
You do not need a smart tv in order to use the roku. Basically the roku device makes your TV Smart. The basic connection is just an hdmi cable, and some type of internet connection. Depending on the Roku you have, you can either go with the built in wireless, or you can hard wire the internet. The same type of cable that you would use to hook up a computer to your router.
Aug 02, 2014 | Roku Televison & Video
TV doesn't recognize HDMI with Roku
The Roku is the problem, not the TV. You need to go to the Roku site and request download information to synch the Roku to an HDMI input.
Jan 13, 2013 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sa-dx1040 dvd optical input works, tv and cd do not.
Jun 11, 2008 | Technics SA-DX1040 Receiver
Televison & Video Logo
41 people viewed this question
Top Hisense Televison & Video Experts
Sean Burke
Sean Burke
David Tickner
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
