Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device./
SOURCE: What is the course Universal GE 25008 remote control for alive 37" sounds bar
02819,02886. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
2. Press the RECEIVER POWER button on the remote.
3. Press the UP ARROW on
the remote, about one press every two seconds. Stop as soon as the sound bar turns
off. This process may take several minutes.
4. Press POUND (#) on the remote. The VCR MODE button will
flash three times.
(VCR button instead of TV button)
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press
VOLUME on the remote to confirm the remote controls the sound bar. If this does not
work, return to Step 1.
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
