Question about Icom Radio Communications
My ICOM 7000 has lost its speaker capability. I have tried the switch on the control head and the speaker on the back of the unit. I still have earphone capability. K1CRR
Posted by Ronald Osimo on
sadiq muhammad
    Champion:
  • Icom Expert
  • 228 Answers
Please check the backside jack for external speaker also check your internal speaker.
Posted on Apr 25, 2019
1 Related Answer
Benimur
Louie Role
  • 6966 Answers
SOURCE: I just bought a KDC
Yes, the Kenwood KDC MP-235 has two (2) line level outputs (RCA types red & white). However, these outputs internally passed through an electronic crossover/filter making them appropriate for subwoofer amps only.
If your unit is an MP-235CR, then the same outputs would be for the rear amp (not subs) and are full range (unfiltered).
If indeed your unit is an MP-235 and if I may make a suggestion, still connect the Kenwood to four (4) speakers. It would not be technically correct to leave the internal amps operating with no load (speakers) connected. Additionally, you would be getting 200 watts (4 X 50) more to your system (since it is already there).
If your Bose amp & speaker are subs, then no issue, however if the Bose is for a full range of speakers, then only the woofer part would be working efficiently.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 15, 2008
My icom-7000 keeps breaking up in receive mode.
Check sensitivity, aerial and aerial connection. Decrease squelch level from 5 to 3
May 12, 2015 | Icom IC-7000 Transceiver
? new bp 200 replacment for bp 199 will not operate my ic t8e radio
The IC-T8E is the Icom VHF / UHF Amateur (or "Ham") transceiver capable of wide-band AM & FM receive and 6 meter (50Mhz - 54Mhz) , 2 (144Mhz - 148Mhz) meter and 70 centimeter (430Mhz - 450Mhz) FM only transmit - when appropriately licensed by your country's communications authority.
RigPix Database Icom IC T8E
Any FM transmitter operating in those frequency ranges will be received and played thru the speaker - unless they are encoded with a squelch decode sub-audible tone or digitally encoded squelch control that does not match the one set to the IC-T8E. Program the squelch to be open or to match that of the transmitter so that the radio will play only when that particular transmitter is transmitting.
An FM transmitter operating in APCO25, DSTAR, etc. will not be decoded as these are digital signals that the ICT82 is not capable of decoding.
I was unable to locate any "BP200" radio you mentioned, so I can't comment on their capabilities or if they have an incompatibility in encoding, frequency, etc.
Mar 11, 2015 | Radio Communications
IC-7000 will not power up
Check your power supply, all wiring for power. Pretty typical when there is not enough voltage.
Mar 08, 2015 | Icom IC-7000 Transceiver
How to repair Icom IC-M700 HF transeiver?
Does it have an external speaker plugged in the back? If so try unplugging it see if the internal speaker works, if it doesnt have an external speaker plugged in try one, maybe the internal speaker went bad from moisture.
May 28, 2014 | Icom M700 Pro - IC AT-130 automatice tuner
Not receiving
Hello
I understand this ICON 802 marine radio will not receive.
There are two things to check for. First check the speaker jack on the back side of the receiver also check the speaker plug and the connections. Make sure that the wires are soldered properly. If you have access to an ohm meter connect it to the plug leading to the speaker, it should measure 4-8 ohms. If the speaker checks ok then check the headphone jack on the front panel. The jack has a contact switch internality to disconnect the external speaker whenever a headset is plugged in. You can clean it by using a electronic contact cleaner spray a little into the jack and plug in a headset and turn the plug back and fourth. If this doesn't work, it would be inside the unit itself.
Hope this helps
Bruce
Dec 21, 2013 | Icom Radio Communications
Icom 7000 switches off when the mike is keyed up and then relay chatters
Check for shorts and opens on the antenna with a meter first.
Mar 31, 2013 | Radio Communications
Hookup icom 7000 to ameriton arb-804 interface to al-811
make sure you are using the correct rca plug in the right jack
you only need key on the amp
on mine it doesnt use the alc cable
Aug 02, 2012 | Icom Radio Communications
I have a kenwwod ddx 6027 double din head unit in my car, what cd interchangers will work with my head unit?
Any kenwood changer will work. That head unit also supports DUAL changers
Any FM Modulated changer wil also work.
Changer Control Features
  • Dual Disc Changer Control Capability (CH1/CH2 & AUX)
  • DNPS (Disc Name Presets) with Compatible CD Changers
  • DNPP (Disc Name Preset Play) by Remote
  • CD Text Ready with Compatible CD Changers
  • Direct Access with Remote
  • Random/Repeat/Scan Play (Disc/Track)
Jan 09, 2009 | Car Audio & Video
ICOM GP-360ML GPS Receiver
I had this problem about a year ago. If all you need is the firmware update they will update it at no charge and they told me if it needs repairs they most likely will not have the parts becaus it is a discontinued model. They also said they did checked it and found no other problems. Sent it in to Icom:
Icom America
2380 116th Ave NE
Bellevue WA 98004
They did the firmware update and sent it back to me free of charge. It works great now and my chart cards work great.
Sep 09, 2007 | ICOM Informatique GP-360ML GPS Receiver
Radio Communications Logo
148 people viewed this question
Top Icom Radio Communications Experts
Vincent G
Vincent G
Ngoro
ray gallant
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
