A.O. Smith GPVH-50 Residential Water Heater, Natural Gas, 50 Gallon, ProMax Power Vent, 40,000 BTU Logo
E
Eric McMillian Posted on May 22, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a AO Smith GPVH 50 100 with an LED status code of XOXOOX. I replaced the burner assembly today and the problem still exist. Any suggestions or a possible resolve would be greatly appreciated!
Steve Pack
Level 3:
  • A.O. Smith Master 7,128 Answers
  • Posted on May 23, 2018
Steve Pack
A.O. Smith Master
Level 3:
Answers
7128
Questions
Helped
2275296
Points
27972
1 Related Answer
Anonymous
  • Posted on Mar 17, 2011
SOURCE: I have an AO Smith
The GPVH has electronic ignition. It does not have a pilot
3answers
AO Smith 2012 water heater model GCV 40 300 pilot lights but then goes out. Won't stay lit
You only need the thermocouple replacing. It is the safety valve that won't let the main burner light unless the pilot is fully lit. As it is gas, you should have a gas certified technician replace it.
A.O. Smith Water Heater. What does error code of 991 indicate?
Here you are Dorothy
AO Smith code 991 Solution for error code 991
Check the gas type of the water heater. Inspect the environment around the water heater. ... Check if there is grease and/or dirt in the burner (Part #101) and the fan motor (Part #103), especially if the water heater has been installed in a contaminated area.
Error code '991' for type ATI-110C-N by AO Smith. Cause and ...
More help here, but you probably need a service call, especially if it is a gas water heater.
https://www.google.com/search?q=error+code+of+991
Whirlpool water heater flash code 6 and burner doesn't come on but pilot is on.
6 flashes is typically found with power vented and flue damper type heaters ... whirlpool never sold a power vent, but they did sell the AO Smith brand flue damper series heater.
The following manual suggest the problem is either gas supply or pilot assembly.
http://waterheatertimer.org/pdf/Power-damper-troubleshoot-parts-manual.pdf
More resources on following link:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#honeywell
Ao smith GPVH 50 100 BURNER WILL NOT STAY . EXHAUST FAN COMES ON IGNITER COME ON , BURNER LIGHTS FOR ABOUT 4 SEC. BURNER GOES OOUT
Low gas pressure, dirty combustion parts, bad gas control valve.
Following link has power vent troubleshoot:
http://waterheatertimer.org/power-vent-water-heater-troubleshoot.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Hot water heater
You need to change the elements out
I have an A.O. Smith Permaglas Water heat (Natural Gas) that will not stay lit.
There may be a draft blowing out the pilot. Place some fiberglass insulation inside the cover for the burner or pull down the insulation from inside the jacket just over the burner opening.
2helpful
I have a GPVH 40 100 AO smith hot water heater.The FV (flammable vapor) sensor has been setoff from us painting the floor yesterday. How do I reset the unit?
AO smith manuals
http://www.hotwater.com/lit/im/r-gas.html
GPVH series manual
http://www.hotwater.com/lit/im/res_gas/315465-000.pdf
You can search the manual for FV
The FV sensor shorted because it detected flammable gas
Quote manual:
Flammable liquids (such as
gasoline, solvents, propane (LP or butane, etc.) and other substances
(such as adhesives, etc.) emit flammable vapors which can be ignited
by a gas water heater's hot surface igniter or main burner. The
resulting flashback and fire can cause death or serious burns to anyone
in the area. This water is equipped with a FV sensor for detecting the
presence of flammable vapors, see Figure 3. When the sensor detects
those vapors, the unit will shut down and not operate. Should this
happen, please refer to the troubleshooting guide on pages 28-30.
Troubleshoot step 14-15 says
replace the FV sensor
call tech assistance number that shows on water heater
AO Smith will refer you to a plumber
I don't believe homeowner can buy these parts due to Federal regulations
The shorted FV sensor probably saved you a flash-over
The cost of 2nd degree burns from a flash-over would be astronomical.
Fortunately you're ok, and the other folk in the room are ok.
In the old days.
Two guys I knew, winter 1978 Chicago, were laying VA tile using the black mastic.
They were killed and the house burned down because of the water heater.
Main office marked the event with a memo saying they still owed money on their account.
The only company with a re-settable FVIR that I'm aware right now is Bradford White
http://www.thetankatwaterheaterrescue.com/forums/forum3/2679.html
http://411plumb.com/bradford-white-defender-water-heater-review
Bradford White Defender FVIR is resettable without buying parts.
AO Smith Burner Issues
This system uses an electrical test to make sure that the burner is lit. The flame sensor will either be broken or will be covered in deposits (clean with an emery cloth).
The flame sensor is usually a small metal rod that would be in the direct line of fire of the burner with 1 wire attached.
CAUTION:
The ignitors can be very fragile and are expensive. They are very brittle, do not touch it.
Burner didn't ignite on my AO Smith model FXGT/PGXT
Unless your AO is a high recover it will take a while for it to fill up with the water that you have used then reheat the water in the tank.
Top A.O. Smith Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you an A.O. Smith Water Heater Expert? Answer questions, earn points and help others
