1967-72 all use the same wiring for signals, here is that diagram.
Here is a link if you can't read this http://www.fooddaily.club/1972-mustang-wiring-diagram/1970-ford-mustang-turn-signal-wiring-diagram-stunning-radio-in-07-1972-with-diag
SOURCE: 1988 Ford Mustang. Turn signals won't work
If the signals come on, but don't flash, check & or replace your flasher, or swap it with hazard flasher if it's the same to confirm flasher is the problem. Hazard & blinkers are on serarate flashers.
SOURCE: 1988 ford mustang. Turn signals do not work
You did not say if its one turn signal or all turn signals that dont work. It could be a bulb.One bad bulb will cause the others not to work , normally one side of the car.Mostly left and right sides of the car is on a different circuits.
If it is all of them not working , it could be the switch in ur steering colum thats bad.Its the switch that the handle u move to turn the turn signals on and off.You would normallytake off the steering wheel to fix that switch.But its a bigger jpb , a pain.So make sure its not a bulb or a fuse first and make sure ur useing the right amp fuse.If its not that.Then id check the conection where the bulb screws into the socket.There can be corrosion there and that can cause a bad conection.Besides a bad bulb thats always been the number one reason my turn signals have not worked.You just have to keep eliminating the possibilities. Keep checking.
SOURCE: 1996 Ford Mustang Timing Diagram
Your timing is controlled by the computer and cannot be adjusted. No distributor. Unless you have a race car, it doesn't get adjusted.
SOURCE: A diagram of a 2003 Ford Mustang interior fuse box?
here you go
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
SOURCE: firing order diagram on 4998 ford mustang...
Firing order diagram on 1998 Ford Mustang V6:
1 - 4 - 2 - 5 - 3 - 6 LEFT bank numbered 1 to 3, right bank numbered 4 to 6
coil Pack:
1 2 3 5 6 4
Please rate my response. Thanks!
