Question about Boating
TORQUE FOR A 1986 EVINRUDE 60HP HEAD - Boating
Posted by ROBERT BURMESTER on
Kardoc
    Top Expert:
  • Boating Master
  • 5,998 Answers
4 Related Answers
Anonymous
  • 88 Answers
SOURCE: torque settings 1986 nissan kingcab head
lookdone ahundred of them o never went by book always on a nissan torque to 40 in center stagger pattern then 80 done any trouble while on job let kme know hey if u dont mind vote for me on fixya
Posted on May 24, 2009
mindreader
Jim DuBreck
  • 578 Answers
SOURCE: 1986 Mustang 3.8L cyl. head torque.
The aluminum heads on a cast iron block require some gentle torque procedures.... It may not be necessary - but I suggest that you start near the center of the head and work out with each tightening step. This will ensure that you don't put too much pressure on a single portion of the head. The standard proceedure for the 3.8 V6 up until 1994 is as follows:
You will have some long and some shorter head bolts. Place a small mark on the long bolts to identify them during the final torque proceedure.
Step 1: 15 (on all bolts)
Step 2: 29 (on all bolts)
Step 3: 37 (on all bolts)
Step 4: Now, starting near the center of the head, loosen a single head bolt about 2 turns. Now, torque it down to about 15 (+/- 3 lbs) IF A LONG BOLT.
OR 11 (+/- 3 lbs) IF A SHORT BOLT.
Step 5:
After all bolts are set as described above, ....go over them 1 more time, starting near the center of the head and pull each bolt down another 1/4 turn (90 degrees).
You are done!!
Posted on Oct 10, 2009
bctillson
Bruce Tillson
  • 164 Answers
SOURCE: replacing cylinder head on 1986 montero with 2.6
How are you going to know which bolts are which in their numbering? Go to an auto parts store and get a Haynes Manual for the car. All of the specs will be in there.
Posted on Oct 31, 2013
txinspector
Raymond Richards
  • 407 Answers
SOURCE: What is the torque specs for a v8 3.6 evinrude heads
Many torque specs can be transposed. the key is to know what other similar models are there. A torque speck is the safe limit to witch to tighten a bolt. so if you can find the similar torque on a similar engine that does not seem too high I would start there. if it is an all cast iron engine I would try 95 foot LBS but is it is Aluminum I probably would not go over 25. Just saying. the torque is also directly related to the compression of the engine and the compression is directly related to the octane required, if you are not required to burn high octane then you have a low compression engine and most likely a low torque speck and if it is an aluminum head and block the very more likely very low torque.
best of luck
Posted on Apr 12, 2015
Will a 60hp evinrude electric tilt/trim work on my 48hp evinrude
yes it will. bigger to smaller is okay and not a GREAT deal of difference in weight.
Mar 13, 2018 | Boating
Water in oil in yamaha out board when old oil was drained no sign of water in oil after changing with new oil now water in oil
You need to replace all the lower seals and o-rings to the prop. I am having this done on a 2014 Mercury 60hp under warranty. Just the luck of the draw. I had a 1986 Evinrude for 6 years with no problems.
May 16, 2017 | Yamaha Motorcycles
What sparkplugs go in a 92 60hp twostroke evinrude
I'd ring your local dealer he should help or email evinrude direct?
good luck.........
Sep 17, 2015 | Boating
1992 evinrude 60hp boat motor
Have you disconnected gearshift rod ? 7/16th bolt under bottom carb
May 13, 2014 | Boating
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
1967 evinrude sport 4 60hp wiring diagram
That came with either battery or magneto. If the distributor is rather shallow and the ignition wires cross the middle of the cylinder head, it is battery, if the ignition is long and the wires cross above the thermostat housing- it is magneto.
That is one of the great historic motors made, but carry lots of gas!
Dec 12, 2011 | Clymer EvinrudeJohnson Outboard Shop...
Torque settings 1986 nissan kingcab head
Feb 05, 2009 | 1986 Nissan King Cab
What is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Jan 04, 2009 | Boating
Boating Logo
171 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
