Question about Kenmore Vacuums
SOURCE: Electrolux Oxygen Canister Vac
Did you check the powerhead drive belt. Procedures for replacement are on the electrolux website and also in the owner's manual.
Posted on Jan 08, 2008
SOURCE: Kenmore powermate front axle fell off
It will go on hard. Just angle it until you have it as far as you can go, then use maybe a hammer to knock it the rest of the way.
Posted on Jan 10, 2008
SOURCE: belt broke, can't get bottom off
if it's the one in the picture then pop off the light cover by gently pushing in and prying on both sides . Remove the bulb by pushing and twisting , OK?, now see the 2 screws? take them out. now flip over the powerhead and gently pry at both sides toward the rear wheels.
Ta Daa!
Posted on Oct 02, 2008
SOURCE: Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Posted on Dec 10, 2008
SOURCE: how do you take the canopy cover off of a kenmore cannister vac?
Flip the vac upside down and look for two screws from the underside near the wheels. If they are not visible you will need to remove hidden screws from above by prying gently at the back of the vac where the body panels meet at the bumper. Also look for two vertical screws in the bag area.
Posted on Sep 06, 2009
