Question about Riccar Sewing Machines
Riccar 525 - is just making a noise when i press foot pedal but foot pedal does not go up and down. It will when I turn dial at right hand side.
Posted by biddy on
R.A. Ellis
  • Riccar Master
  • 12,731 Answers
If you can hear the motor whirring and nothing is moving, it's possible the machine has seized due to lack of regular oil and cleaning.
Wheel on right side that controls the needle up and down is very tight...
Posted on Jun 03, 2018
William Wright
    Habit-Forming:
    New Friend:
  • 85 Answers
If the bobbin winder is not engaged, then the motor belt is off. That’s why you can hear the motor but nothing happens
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_affa8ba20bcbf6c9
Ruth summersides
    Genius:
  • Riccar Master
  • 1,477 Answers
Sounds like it's shorting.
out. Be careful, unplug it before you check the pedal for loose wires etc.
5 Related Answers
Anonymous
SOURCE: foot pedal and thread guide
Same thing happened to my CE-200. It would only stitch one stitch at a time or else it would run full speed. My husband made an adjustment through a small hole on the back of the pedal and it now works much better. The adjustment hole apparently allows you to set the sensitivity of the electronics inside the pedal. He turned it slightly toward the + direction. It took a couple of small adjustments to get it to work nearly normal again.
[email protected]
Posted on Jul 14, 2008
Anonymous
  • 11 Answers
SOURCE: janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Posted on Jun 16, 2009
Anonymous
  • 55 Answers
SOURCE: No matter how hard I press down on the foot pedal
is the machine easy to turn by handwheel? if not it may be seizing and needs servicing.
if the machine is free to turn by hand it sounds like your foot control is in need of repair or replacement - see a tech.
scott.
Posted on Jul 27, 2009
daviescry979
monster chick
SOURCE: my needle won't move up or down when I press the
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Posted on Nov 25, 2011
Jimmy
  • 539 Answers
SOURCE: janome 7025 is making a grinding noise before I even push the foot pedal
When was the last time you oiled it? Go to http://fixsewingmachine.com for instructions. Jimmy
Posted on Apr 10, 2012
Riccar 525 - makes a birring noise when I press foot pedal but the needle does not go up and down. I can turn dial at right hand side ok.
Sounds like the motor is trying to run but the other machine parts are not moving. If your machine is an older mechanical (not computerized), then it's very possible the machine has seized due to lack of regular cleaning and oiling. Avoid trying to run the machine in this condition as it can damage the motor.
May 22, 2018 | Riccar Sewing Machines
My riccar 555su machine starts sewing as soon as I plug in. Foot pedal is stationed inside cabinet by knee, but I'm not controlling it.
The pedal is stuck in the ON position. Unplug the sewing machine and try to open up the pedal to inspect it. Or try pressing the pedal a few time to loosen up the pedal movement. Good luck!.
Oct 24, 2016 | Riccar Sewing Machines
Machine is behaving as if not getting any power, but light is on. Press foot pedal and absolutely nothing happens
There is probably a bad connection in your foot pedal. Try moving it around with your hands at the contact points while pressing to activate. If it goes when you are shifting its position then it needs to be fixed or replaced.
May 20, 2014 | Janome Sewing Machines
Riccar stitch crafter 950 parts locator?
here's a link for a manaul, at the riccar website,
you have to click on the link
then you'll see a picture at the bottom right hand corner look for
ENTER SITE and click on it
there will be a menu with pictures look toward the bottom of the page
toward the right side, look for manuals
click on manuals
on the right hand side of page look for SEWING MACHINE OWNERS
MANUALS
look for a R 950 and see if that's the right one for the machine
check these links for parts
http://www.sewingmachineoutlet.com/rictn.htm
http://www.brewersewing.com/BQSS_Consumer/productmain.asp?category=Parts&subclass=Spool%20Pins
http://233131.r.msn.com/?ld=6vD2KIefecEmEKmd8Cb66bCzVUCUxUVu_EozjiQVpx8Z6NzLOjF_h-iAfSLEVoyZGPg0H5SIE_3neC72GO4P2GW0cigtzqk1OZN6OxQc7WjMvVRIDpW9mRz5YRsQBS1wZiqREdUA&u=http%3a%2f%2fwww.sew4less.com
http://www.monstermarketplace.com/sewing-machine-parts/riccar-parts
http://www.mysewingmachineparts.com/riccar-parts/
http://www.gallsewingvac.com/Riccar.aspx
Oct 21, 2012 | Sewing Machines
Bobbin won't wind - foot pedal working but bobbin won't turn ES2020 New *unused just stored since purchase from new*
Your new but stored machine has sat long enough that any oils from the factory have become gummy and or dried out. I would take it in and have the pros service it. But for now you might try....
Turning the hand wheel by hand while you press on the pedal. This MAY free up the machine enough for the motor to take over.
Jul 21, 2012 | Sewing Machines
The handwheel is extremely hard to turn. it will turn using the foot pedal but it makes a whining noise. could it be the belt?
Look on the back of the machine there is usually a tension dial. Try adjusting that. I f that does't work your manual lists instructions for cleaning and oiling a little bit of oil in the right place works wonders or on the oher hand a little thread in the wrong place will stop an electric motor.
Feb 23, 2011 | Brother LS-2125 Mechanical Sewing Machine
Need to know how to thread a 550 super stretch Riccar sewing machine?
  • Unthread the machine.
  • Raise the presser foot.
  • Turn the handwheel until the take-up lever is at it's highest position.
  • Set the upper tension dial/knob to 5.
    The threading path is as follows:
  • From the spool around the top guide, down through the right slot, up the left slot, through the eye of the take-up lever from right to left, down through the guide(s), through the needle from front to back.
Nov 09, 2010 | Riccar Sewing Machines
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
Riccar 9600, no manual, how do we thread it?
If I remember it is reel of thread on the reel pin, make sure the presser foot is up and takeup lever at the top, take the thread to the left and over the top cotton guide, straight down through the tension disc and down to the larger guide, round the right and take the thread back up the left hand side, through the takeup lever right to left and follow the guides all the way down to the needle, thread needle front to back.
Mar 28, 2010 | Sewing Machines
Won't sew when foot pedal is pressed
foot pedals do fail and possibly your s has .
Oct 31, 2017 | Kenmore Sewing Machines
Sewing Machines Logo
102 people viewed this question
Top Riccar Sewing Machines Experts
Chris Wetmore
yobo007
yobo007
Ngoro
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
