Question about Pets - Others
How to remove batteries on pet series - Pets - Others
Posted by Y. B. Caywood on
  • Stephen Miller Feb 10, 2019
    Hi Y. B. Caywood, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
How do I take off Blade
I'm pretty sure from memory the blade will pull off from the front edge. There should be a black metal bar at the rear end of the blade which you can push in so the blade will pull off.
How do I change the batteries in the Zhu zhu pets?
Changing the Batteries
A. Turn the pet over and unscrew the
motor box
B. Remove the motor box.
C. Replace the two AAA batteries matching the
polarity shown inside the battery compartment.
Be sure the batteries are firmly seated.
D. Replace the motor box and screw snug.
How to change battery
Wahl chromado how to replace battery - Fixya
www.fixya.com/support/t22389742-wahl_chromado_replace_battery
Dec 24, 2013 - Where to purchase battery pack for wahl chromado clippers. from the whal parts ... Feb 16, 2015 ' Wahl Chromado Professional Cord/cordless. ... Jan 02, 2014 ' Wahl Adjustable Chromado Cord/Cordless Pet.
No parts required.
  1. Step 1 Disassembling of Wahl Lithium Ion Trimmer. ...
  2. Remove the screws from the top to take the metal piece and plastic part off. ...
  3. Pry open the plastic cover into two separate pieces. ...
  4. Here is the final result. ...
  5. Step 5 Lithium Ion Battery Replacement.
Wahl 9590-210 Pro-series Complete pet clipper kit - corded and cordless operation, will not charge, only used once, bought new on US amazon using in Perth aus., it looks like the resistor has blown, the...
Is it the correct voltage? Check your transformer specifications, operating voltage will be written on it. If the blown resistor is on the PCB beside the battery it is not supplied as a separate part, it comes on that PCB. www.unityagencies.com.au will be able to direct you to an agent able to supply parts.
1helpful
Good afternoon, I search a french instructions for Micro Pets tomy "Gork " Serie 2 U.S . I have forget my instructions list :/ Please help me. Thank you
If you have a brand-new MicroPet, remove the"Try Me" plastic strip before using the pet.Turn the MicroPet over and locate the plastic strip protruding from the batterycover; pull the strip straight out.
    • 2
Change the batteriesif the power is running low -- the included batteries are used for testing andmay not be fully charged. Turn the MicroPet over and use a Phillips-headscrewdriver to remove the screw at the top of the battery cover. Slide thebattery cover out and remove the old batteries. Insert two LR44 batteries,making sure to match the polarity as instructed. Replace the battery cover andtighten the screw with the screwdriver.
    • 3
Wake up your MicroPet by pressing the button onits head; it will perform an action to let you know it is awake. Say a phraseto your MicroPet, then wait for its nose or tie to light up. Now say a secondphrase and the MicroPet will follow your command. For example, say,"Robo," then wait for the pet's nose to light up, then say,"Run," and the MicroPet will run.
    • 4
MicroPets display two "moods,""happy" and "bad," depending on the commands it receives.If you repeat the same command over and over, your MicroPet will display a"bad" mood. It will then refuse to listen to your commands and willnot respond to you. Praise yourpetto cheer it up and make it happy. For example, say, "Good job," toyour MicroPet.
    • 5
Press the button on top of the pet's head while itis performing a command to reset the MicroPet.
    • 6
Hold down the button on the top of your MicroPet'shead for three seconds to make it go to sleep; it will sing a goodbye songbefore shutting down.
    • 7
Make your MicroPet sing one of three songs byclapping your hands. Clap three times for "It's a Small World," fourtimes for "Ten Little Indians" and five times for "ElectricalParade." Make sure to wait for the pet's nose to light up between eachclap. Place multiple MicroPets together and they will sing in unison.
    • 8
To program your MicroPet, turn the MicroPet off,then press the button on top of its head six times --- the pet will light up,then make three small beeping noises. Wait one second and the pet will light up--- press the pet's head button now if you want to program the "GoForward" command. To program the "Turn Right" command, wait forthe pet to light up twice, then press the head button. To program the"Turn Left" command, wait for the pet to light up three times, thenpress the head button. When you hear three beeping sounds, the MicroPet isfinished programming and will perform the commands. You can program up to fivecommands in a row. When in program mode, your pet will not respond to your voicecommands or sing songs. To go back to the normal command mode, simply turn theMicroPet off then back on.
My brand new bissel little green proheat pet series is spraying solution however it's not hot when it comes out. I put hot water in the tank & turned the heater on. Isn't this the whole point?
Have you checked the user manual? Can be found at http://www.bissell.com/searchresults.aspx?searchtext=little green&mode=userguides
If there is no element then the water will cool down naturally.
Pets - Others Logo
Top Pets - Others Experts
Tom Chichester
Ruth summersides
Kardoc
Are you a Pets - Other Expert? Answer questions, earn points and help others
