Question about Neff Cooktops
Wiring diagram for Neff hob t46fd53xo - Neff Cooktops
Posted by Debbie Tilbrook on
5 Related Answers
Anonymous
SOURCE: Neff 4 ring, ceremic top hob - how do I turn on!!
You press the "on" which is on the left. Press the picture of hob you require and press the up and down for temperature. Then put your pan on the hob and it will work. If you need to adjust the temp you need to remove the pan.
Posted on Jun 18, 2008
Anonymous
SOURCE: Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Posted on Jun 13, 2009
Anonymous
SOURCE: Neff instructions
Visit http://www.bshcustomerservice.com/
And enter your model number to download a PDF instrustion manual.
Posted on Jun 25, 2009
Anonymous
SOURCE: Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Posted on Nov 06, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: ignition not firing on a neff hob, gas fine
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 19, 2010
Hob ceran replace with new induction hob
Need looking at by NEFF , a big job .
Mar 16, 2015 | Neff Cooktops
Induction hob neff T4243 has cracked will I need to replace it
Did you crack your hob by means of impact or did it happen on its own accord?
I have a neff induction hob and has just cracked in 3 directions while cooking this evening. I am just trying to determine if there is a common fault with this neff product or I am just unfortunate. Mine is under warranty and have a engineer coming on Monday, so have the whole weekend with no hob as I have been advised not to use it.
Many thanks
Feb 28, 2012 | Cooktops
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
Jul 28, 2010 | Neff Cooktops
How do i unlock my neff hob? Red key above on/off switch wont go off! Cant use hob.
Hi I have just had the problem of accidently locking my Neff Hob.
If you hold down the L Lock button for about a minute it unlocks.
Mar 18, 2009 | Neff 23 in. T4343 Electric Cooktop
Nov 28, 2008 | Neff T1323 Electric Cooktop
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Oct 15, 2007 | Neff 23 in. T1443 Electric Cooktop
Cooktops Logo
392 people viewed this question
Top Neff Cooktops Experts
Lee Hodgson
Lee Hodgson
Paul Carew
Andrew Taylor
Andrew Taylor
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
