Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
LG dishwasher model LD-14AT2
HE error keeps coming up. what does this mean?
Posted by Dorothy5 on
Ian Greenland
    Sergeant:
  • 351 Answers
Normally means not heating check element and use less soap
Posted on Mar 03, 2008
E1 error, pump spinning but not pumping
Just replaced wash pump unit
Thanks anyway
Ernie
Jun 11, 2009 | LG LDF6810ST Stainless Steel Built-in...
Water heater no go.
The heating element is turned on first during the main wash cycle, which could be approximately 10 minutes in. Since this error is coming up, the first thing to check/replace is the heating element.
I am only familiar with the LDF family of LG dishwashers and on them, to get to the heating element, you pull the dishwasher, invert the entire DW and remove the access panel.
Good Luck, please post back here what you find, OK?
May 07, 2009 | Dishwashers
LD model LD-14AT2 dishwasher
Are you getting an error code displayed when this was happening?
How did you fix the problem?
Aug 25, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
OE fault in Dishwasher model LD-14AT2
suggest you take the drain pump motor out and inspect. either a blockage or its defective.
Jun 15, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Lg dishwasher model LD - 14AT2
E1 is usually a very common fault of the wash motor not working.
The impeller breaks away from the motor shaft and doesn't spin, therefore, it doesn't pump water.
There is a sensor that activates with low pump pressure, which shuts down the machine and displays the error, E1.
The only other causes (that I'm aware of) are leaking water supply hoses, or pump blockage, but the motor fault is by far the most common.
Hope this helps.
Mar 18, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LD 14at2 lg dishwasher
Does it display an error code" eg: E1
Jan 05, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD-14AT2 - Error message about filter
HI, WE HAD THE SAME ERROR AND WERE ADVISED - AFTER WE CLEANED EVERYTHING - TO NOT USE A LIQUID CLEANER AND USE A TABLET.
Nov 28, 2007 | LG 24 in. LD-12BW5 Free-standing...
EI error code.
e1 on any LG d/w means the water pressure is insufficient due to the wash motor being faulty and /or the capacitor connected to it.
take care.
Jan 01, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
LG Diswasher model LD-14AT2
NEED TO SORT OUT LEAK FIRST AS THIS HAS ACTIVATED YOUR SUMP LIMIT SWITCH. THE CYCLE WILL NEVER PROCEED OTHERWISE.
Jul 29, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
223 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Bill Johnson
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
