Batteries may be corroded after so many years.
Testimonial: "Thank you for answering. Should I be able to turn the camcorder on only with de DC power plugged in or does it need a working battery?"
The manual doesn't say.
https://www.manualslib.com/manual/80723/...
SOURCE: cannot find driver for jvc GR-D720 Mini Dv digital camera please help!
If it's a JVC GR-D72, then it's MiniDV. Connect the camcorder via firewire to your PC
SOURCE: JVC GR-D250 Mini DV Digital Camcorder Authorised service center in pune india
This model is not supporting with pc when you play cassette only it is supporting with memory stick
SOURCE: My computer no longer recognizes my JVC GR-D70U mini DV cam when I plug it into a usb port.
I am not sure. But I believe the camcorder has to be on when you connect to the computer.
and I assume you use firewire for this particular camcorder.
I too once had this problem when I used Windows Vista.
If you too use Vista, try it with Windows XP.
cheers,
SOURCE: How to use an SD card to record on a JVC GR-D370 mini DV?
Download PC Inspector File Recovery.Thank
