Husqvarna Rider 155 No steering Rear end of cable looks okay
The steering is fairly basic, a steering wheel that turns a steering shaft, on the end of the shaft is a sprocket, around the sprocket runs a short chain, on either end of the chain is a steel cable, both cables run to a quadrate at the underside of the engine, the r/h cable then goes the the l/h fixing and the l/h to the right, so either the locking screw on the steering wheel shaft has come loose and not turning the lower shaft, or the sprocket has sheered from the lower shaft, or the cables are not adjusted correctly, remove the cover on top of the chassis between you feet, you will then see the lower shaft, sprocket and chain, you should see the problem when the steering is turned.
