SOURCE: Bernina Activa 130/131
Because you say all was working for a while before this latest event, it will be the supressor that has failed, they are generally in the foot control (some machines have them in the main body near the power inlet) and it needs to be removed, it only stops interference to Radio & TV and is not necessary for correct function...............your nose will tell you if it is in foot pedal or inside the machine..
Unplug from mains, undo cover/s and find the electronic looking item which is cracked, burnt & probably oozing brown goo and smelling like burned plastic only worse.... Simply remove this from the circuit, clean the region with some denatured spirit, methanol or similar, wait until completely dry and re-assemble....this should fix the problem of the machine "running on" by itself....as to whether you have done a good job of the initial electrical repair, only you will know that.
By the way, how's the dog ? Guess the machine was not plugged in at the time !!
SOURCE: Bernina Activa 135 sewing machine
Hi , the pedal micro switch are stuck , you may visit fixya repair service just , (enter zip area), you can find sewing machine repairman near you
SOURCE: my machine has power, but foot pedal only makes needle go slowly
sounds like the contact in the foot peddle has failed try a new peddle
SOURCE: my bernina 630 is sewing slow and will not speed
i was able to find it at www.ifixmachines.com
SOURCE: foot pedal dead, machine keeps sewing!
Sounds like your foot control is faulty.
I can supply foot controls for 99% of sewing machines.
Mike
[email protected]
http://www.sewingmachineswales.com
