Double check all the power options on your PC to make sure it is not set to go to sleep or hibernate or any other process that may
interrupt the backup itself.
Also make sure there is enough space to back up to.
Make sure that the interface you use to connect also has any power saving turned off.
Many devices have the option of going to sleep or turning off to save power and you would need to check the full properties of your
usb or
firewire card to check that.
Make sure your
antivirus or any other application is not set to scan or run during the same time interval as your backup
when you have checked all that you may find that it now works as it should.
http://www.ehow.com/how_5097708_turn-off-power-saving.html has some useful info as does
http://www.howtogeek.com/howto/windows-vista/disable-power-management-on-windows-vista/
If this information was useful please click
