EDITED OK! I found THIS:
"This dispenser ice chute door and motor assembly opens to let ice through when dispensing into a glass or other container. The assembly may include multiple parts; refer to your parts diagram for a complete list of parts included."
I SEE that assembly, it's motor AND associated gears for the FLAP!
You can hear the motor so I suspect the mechanics next. Could be the gear from the motor shaft is loose or worn?
https://www.ebay.com/i/192508879235?chn=ps
Please know this MAY NOT be your specific part! But the photo is very useful!
Ahaaa! Check the tray "water fill tube"! It's usually rubber and the insides sometimes FREEZES and BLOCKS with ice!
ALSO, I've seen similar problems when the WATER FILTER is too old! Internally it's compacted and blocked so water flow is restricted... SO as the tray TRIES to fill, the water just dribbles into the tray then freezes in the fill tube ~ rather then a true FILL/STOP action.
Anthony
The ice cubes are already made. Probably not that issue. The ice cubes are already sitting in the tray. When I try to use the ice dispenser with a glass I hear the motor running but no cubes are coming out.
Shucks! So sorry! You DID specify "Door ice dispenser".
I HAVE UPDATED my original post and I hope it's helpful!
Apologies.
Anthony
SOURCE: Whirlpool side by side GS6NBEXRS01
If the motor is humming, Take the ice bin out, rinse the bottom shaft connection with warm water, it may just have ice build up.
SOURCE: New Kenmore Elite ice dispenser not working but water is
ther is no ice comming out, it suddenly stopped. Kenmore Elite I dont know whats wrong with it I know that water may not be getting into it but how do I solve this problem
SOURCE: Ice maker won't make ice after emptying ice bin manually.
make sure you push the ice lever back down
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
