Question about Home Security
Sannce model DH41NK account locked? How to reset dvr
Posted by Shawn Faircloth on
Laquain Williams
    New Friend:
Hi I need help
Posted on Apr 27, 2019
1 Related Answer
donaldayers0
Don A
  • 2770 Answers
SOURCE: Resetting my password on my sannce DVR. The model is Dg81cp. Dg81cp
http://cctvhelper.blogspot.com/2016/03/resetting-sannce-dvr-system-password.html
Hopefully, this will help. Otherwise, you might have to contact their support.
Posted on Apr 20, 2018
Where is the reset button for a sannce dvr
hi Ramona.
this is a forum link with people with the same problem you have got and it is telling people on how to reset this dvr.
this is not to say it will help you but go and have a look.
https://www.avforums.com/threads/sannce-dvr-system-reboot.1905253
you could also try this link and see if it helps you out.
Where is the reset button for sannce dvr Google Search
Nov 21, 2017 | Televison & Video
I purchased a NIGHT OWL modelxhd50288p 8ch v 2tb 5mpcam system and forgot pw and dvr is locked how can i reset it
hello friend. idont known much about this night owl model dvr.but i can suggest small technique which we use i n chinese dvr.open the dvr look for 2030 small battery fixed in the board remove it .start your dvr reset to factory setting once then insert the battery again.i hope your dvr is ready.
Oct 25, 2017 | Night Home Security
Sannce DVR-DH81NK1T i am lock out need code or password
Connect dvr to local network
boot up the dvr
connect to local network with a computer (eg Mac)
login into admin screen of your router to identify the assigned ip address of the router
start a terminal session
telnet to the ip address
default user name : root
default password : xc3511
[email protected]:~$ telnet 192.168.0.3
Trying 192.168.0.3...
Connected to 192.168.0.3.
Escape character is '^]'.
YourCCTVDVR login: root
Password:
BusyBox v1.16.1 (2014-12-24 15:47:14 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
Welcome to Monitor Tech.
[[email protected] /]$ cd /
[[email protected] /]$ ls
bin etc linuxrc proc share usr
boot home mnt root slv var
dev lib opt sbin sys
[[email protected] /]$ cd mnt
[[email protected] /mnt]$ ls
custom dvs logo mtd usb web
[[email protected] /mnt]$ cd mtd
[[email protected] mtd]$ ls
Config Log
[[email protected] mtd]$ cd Config
[[email protected] Config]$ ls
Account1 StorageCfg network
HvrMode SysComs ppp
Json SysTime resolv.conf
RT2870STA.dat dhcp.cfg uboot_env_lang_video
There will be an Account## file for each account you have set up
Remove all of these files
[[email protected] Config]$ rm Account1
Reboot your dvr box and it is at the first setup screen
Here are the commands - note you can't send password as part of the telnet command
telnet 192.168.0.XX
root
xc3511
cd /mnt/mtd/Config
rm Account*
exit
CCTV Networking Technical Support
Apr 10, 2017 | Home Security
What channel type do i use on my sannce dvr, 8 out, using 4
Look next to the outs there's one out you need a box to a.c. converter plug male to female then a.v on your tv
Feb 16, 2017 | Home Security
How do I reset .y password on a sannce DVR system?
you may replace the battery inside DVR set
Feb 16, 2016 | Home Security
How do I factory reset?
Remove the dvr cover and find the on board battery remove it for 10 sec and put it again while the power off
Dec 01, 2015 | Home Security
Resetting a sannce dvr
How do I get in when I forgot my password mode l DE,81N1T
Oct 01, 2015 | Home Security
How do I reboot sannce dvr
Try to unplug it from power, wait a few minutes and then plug it back in.
Sep 29, 2015 | Televison & Video
Home Security Logo
1,794 people viewed this question
Top Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a Home Security Expert? Answer questions, earn points and help others
