SOURCE: Spilled soda inside my tv by accident
SOURCE: Soda spill
If you turned it on while it was still wet inside, a short circuit may have occured. I don't advise opening the camera unless you are trained to do so.
SOURCE: kid spilled soda now keyboard will not type
Hi There !!
Thank you for choosing Fixya. The chances are rare that it would work, because liquid may have done damage to the integrated circuit.
But we can give it a try:
What you will need:
Shutdown your PC and remove the mains plug, unplug the keyboard(remember where it was plugged in) and hold it upside down to releaseany debris from inbetween the keys.
This is where the patience comes in, make a note ofthe position of all the keys or you will have trouble putting them backcorrectly, alternatively just remove the letter keys A - Z from the keyboard (which is where the most of the dust/debris will be) and refer to fig 1.4 as a reference to put them back.
All the keys can be removed although the larger keys (space bar, enterkey, shift keys, backspace, caps lock, etc) can be difficult to putback so you might avoid removing them.
Remove the keys using the screwdriver, ease the screwdriver under the key and gently lift the key top off (see fig 1.3).
note: don't forget to make a note of their position !!
When you have removed all the keys (except any keys youwish to avoid) use the compressed air (or vacuum cleaner) to remove anydust and debris from inside the keyboard.
Now is a good time to give the keys a proper clean, for bestresults clean each one individually (the patience thing again) with thecloth and cleaning fluid, when clean, wipe them over with the drycloth.
Before replacing the keys, take your lint free cloth anddampen it with your cleaning fluid (don't put the liquid directly onthe keyboard), give the surface of the keyboard a good wipe overensuring to clean as much as possible any keys that you haven'tremoved.
When the keyboard is nice and clean replace the keys according to your notes or if you have just removed the letter keys use fig 1.4 as a guide, to put the keys back on position the key in place and press gently but firmly until it clicks home.
After replacing all the keys give the keyboard a quick wipe over with your dry cloth and you have a nice clean keyboard.
Hope this will help !
Regard's
SOURCE: is there anything to do for when soda pop gets in camera and it doesn't work
Its depend on the quantity of the soda or drink spilled on the camera you are using. Use the blower to dry the liquid and do not use it at least 10 to 12 hrs. Allow more time to drying.
SOURCE: spilled soda on my camera sticky lens
Buy lens cleaner, to wipe off what you can, but in truth the lens should be dis-mantled to clean it properly not to mention the rest of the camera.
