Question about Clymer Evinrude/Johnson 2-40 HP Outboards Includes Electric Motors 1973-1990 - B732
115 johnson moor spits and sputters when idle and stalls when shifted into gear
Posted by Julia Allen on
Ideal adjustment on 1996 115 hp oceanrunner Johnson out board motor
Idle adjustment is done on the left (driver) side of the motor by turning the adjuster on the black cable running to the control box at the console. There are 2 one is tensioned to select the gearing. F - N - R
Sep 16, 2018 | Johnson Boating
My daughter has a 2001 Kia Sephia that runs fine idling in park. When she shifts into gear, it sputters and stalls. What could be causing this?
I would clean the inside of the throttle body first. Back of the plate and where it seats. Doesn't clear up. Check compression next. It is a 2001.
Jul 02, 2016 | Kia Cars & Trucks
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
Transmission
Try cleaning the idle speed control valve and the throttle body, then disconnect the battery negative and let stand for 5 minutes and try it.
Jan 22, 2014 | 2004 Chevrolet TrailBlazer
Fuel cutting off as I drive
oil sending nit is bad..works the oil pump
Sep 23, 2012 | 1991 Suzuki Samurai
Stalls in drive, runs grear in reverse
Engine stalling and rough run issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Jul 06, 2012 | Cars & Trucks
My jimmy will start and idle just fine however when I start to drive it,it sputters and spits then stalls out. when I restart it I have to floor it to get it to start again. if I rev it to about 6-8000...
i would suggest changing the fuel filter if this does't work check the fuel pressure. and get a mechanic to check the ecu fault codes. as this could be caused by a electronic fault.
Mar 09, 2011 | 1996 GMC Jimmy
1992 SE maxima jerking, sputtering, stalling
I had a similar problem and resolved it by replacing the mass airflow sensor. Ive got 235k+ miles on my 1992 Maxima SE.
Still runs good but having problems with the alarm system.
Jan 27, 2009 | 1992 Nissan Maxima
Clymer Evinrude/Johnson 2-40 HP Outboards Includes Electric Motors 1973-1990 - B732 Logo
187 people viewed this question
Top Clymer Boating Experts
Andrew Taylor
Andrew Taylor
ray gallant
Tom Chichester
Are you a Clymer Boating Expert? Answer questions, earn points and help others
