Question about Music
Hi becky
from looking up the model some of the prices were only 30.00 to 40.00 dollars needing repairs other units/ models went higher in price depending on model and if they where in good repair.
so the decision for u would be is this the organ that you want to restore or do you want to look for other units?
Posted on May 19, 2018
SOURCE: lowrey catillion organ with loud static noise
Try posting on the organforum.com.
It sounds like the power amp has a problem. Probably filter capacitors have gone bad.
Posted on Oct 25, 2009
SOURCE: Turn on the organ and get a loud hum.......
Chances are you're hearing "60-Hertz" hum that comes from poor filtering in the organ power supply. Electronic circuits need direct current (DC) but our power lines supply alternating current (AC). The power supply converts the AC to the various DC voltages needed. Parts called filter capacitors smooth out the voltage, and if they go bad or lose contact because of bad connections the result can be the hum you're hearing.
There are other possible causes, but the filtering is so common it's a good place to start. You don't give the age of this organ, but if it's one that has been around a while, it's a good bet some of those capacitors are worn out.
If you can post a follow-up with a make and model, I'll check some of the technician groups and see if anybody has service information.
Good luck and thanks for using Fixya!
Posted on Feb 11, 2010
SOURCE: Baldwin Model 230 DE when turned on makes a loud
If the organ has a reverb spring "tank" in it, that is likely where the spring sound comes from.
The initial noise is likely due to the initial unbalance of the power audio amp.
Lesser organs don't disconnect the speakers till the amps attain balance so the inrush pulses the speakers..
Posted on Mar 10, 2010
SOURCE: Have an older Lowrey organ with loud hum.
Of course it is repairable.
Find a competent repair person. You did not describe the "noise". If it is 60 cycle hum, the filter caps need replacing. If it is an organ tone, then probably a key contact is stuck.
Posted on May 05, 2010
SOURCE: Our Baldwin electric church organ is over 30 years
Probably worth getting a new one. Try the keyboards from yamaha, they have good organ sounds.
Posted on May 06, 2010
Jun 05, 2018 | Music
Mar 27, 2018 | Music
Mar 20, 2018 | Music
Jan 28, 2016 | Music
Nov 13, 2015 | Music
Sep 10, 2015 | Music
May 05, 2010 | Music
Mar 10, 2010 | Michael Kelly Music
Jan 06, 2010 | Music
238 people viewed this question
