Question about Cub Cadet Garden
On cub cadet RZT 42 mower where do I connect the two ground wires to starter Solenoid
Posted by Jimmie Rosenthal on
Jim flowers
  • Cub Cadet Master
  • 1,098 Answers
If it is 3 pole they will attach to the body with the solenoid bolt. if it is a 4 pole it will attach to one of the small studs.
Posted on May 19, 2018
5 Related Answers
pippall
Philip Long
  • 1486 Answers
SOURCE: my rzt 50 series cub cadet zero turn mower slows
The saftey wires wont cause it to slow down.Thats more of a fuel problem.Check the carb remove and clean the float chamber.Also check advance and ****** springs are still in good working order on carb.
Posted on Jul 06, 2009
Anonymous
  • 323 Answers
SOURCE: install belt on cub cadet mower
First, make sure you have the model number and serial number (located under the seat) and then go to www.cubcadet.com to get a belt diagram so you know which way the belt snakes through the pulleys.
You will have to remove the two pulley covers on either side of the deck.
Fit the belt around the right side of the deck pulleys when you are on the left. There is an arm attached to the springed pulley on the left side. It will have a hole the size of a 3/8" driver/ratchet. Set the ratchet on unscrew (to the left) and push the arm in toward the center of the mower. You will see the pulley moving too, creating enough slack to slip the belt over the edge of the rim of the pulley with a little elbow grease. If it is too tight, get someone to push in with the ratchet while you slip it on. Once again, you are the grass cutter king!
Posted on Jul 25, 2009
Anonymous
  • 66 Answers
SOURCE: The mower deck on our Cub Cadet RZT 50 mower stopped working
You can check the clutch by taking a wire from the ground and a wire from the positive side of the battery and energizing the clutch directly with the belt off to see if thats it. It could simply be a wire loose in the connection on the clutch....their soldered on.
Posted on May 31, 2010
Anonymous
SOURCE: will not move
The transmission is shot. A common problem. Mine died after 3 years and 200 hours of use. Estimate to fix was almost $2000. I scapped it and bought a better mower. There was a rtransmission design defect in the RZT series.
Posted on Jun 21, 2010
Andrew White
  • 2239 Answers
SOURCE: Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Posted on Mar 07, 2012
How can I determine which safety feature is not allowing me to start my cub cadet rzt 42 lawnmower?
You first need to find out why this safety feature is being triggered rather than bypassing it for your safety.
Jun 07, 2016 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
HOW TO RESET THE BLINKING OIL LIGHT ON A CUB CADET RZT
The dashboard for Cub Cadet/MTD mowers includes hour meter, Low oil, or time for oil change, PTO, and other lights. If the oil light is flashing, it means 1 of 2 things. Low Oil Level, or it is time to perform maintenance by changing Oil and Filter. After this process, the light will reset itself after a few more hours of running.
Sep 08, 2014 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
I have a 2006 Cub Cadet RZT 42 Zero Turn Mower that keeps blowing the fuse. It would blow the fuse after long periods of use but it's gotten shorter and shorter between fuse blowing. Now it blows the fuse...
you have a wire that is grounding out, I would check the wire coming from the connector on the voltage regulator to the battery. This is the one in the middle position, look for a rub through and tape it up.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 02, 2010 | Cub Cadet Garden
Garden Logo
218 people viewed this question
Top Cub Cadet Garden Experts
dannydoesita
Marvin
Marvin
Dennis Key
Dennis Key
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
