Question about Kodak Office Equipment & Supplies
How do I reseat the printhead ribbon cable on my Kodak ESP office 6150 printer?
Posted by Mary Reina on
5 Related Answers
Andrew Perrong
  • 285 Answers
SOURCE: Kodak ESP 9 All In
push the button on the top left of the printhead after removing the black and color ink cartridges
Posted on Jan 28, 2009
sajid_najmi
Sajid Najmi
  • 31 Answers
SOURCE: replacing printhead on Kodak ESP 5 Printer
you need to lift printer front access door , take both ink cartridges out,
the carrier (black piece) is called printhead.
When you see carefully at the center , there is a gray latch. you need to "pull it up", it will release the printhead.
MS
Posted on Jun 13, 2009
Anonymous
SOURCE: Replaced printhead and ink cartiages on a Kodak ESP.3
I had my esp3 stop printing black also. I bought new cartridges even tho' I knew the ones in the printer were at least half full. Still not printing black. I finally called Kodak support and got a tech who was the first tech from India who could speak English well. He was very helpfull but in the end he told me he would send me the printer head because that was the problem. My printer was not used for about a month and the head dried up. The tech said that printer must be used about twice a week and the best way was to print the test by using the 'Scan' and 'Copy' at the same time. There was no sense telling the tech this is a huge flaw in the printer as he must have been hearing this for a long time. After I received the new printer head it prints fine. This is an absolutely huge flaw in this printer. If they can't make a different style of head for this printer these will stop being used................. So if you have the ESP3 (I don't know about the other models) and don't use it often the head will dry up and you can't clean it (according to the tech I talked to). Kodak should send these free for the life of the machine in my opinion.
Posted on Aug 08, 2009
Anonymous
SOURCE: Kodak ESP 7 all-in-one printer. I have just replac...
I have had the same issue - only bought my ESP7 last month - have been on the chat support with Kodak in US and they advise that the print head will need replacing but they couldnt send one from US and advised me to ring the 0870 Kodak support number in UK - this is a premium line and lucky I took out an instant replacement policy when I bought it so I am off to PC world to get another! Good luck with yours - suggest you phone Kodak and ask for a print head replacement which should be free if you have had the printer less than 12 months - make sure you have the serial number of the printer with you when you phone. Good luck!
Posted on May 24, 2010
How to remove print head on a Kodak ESP 5250
If the ink cartridges and printhead are already in the printer, remove them, then reinstall them.
  1. Remove the color and black ink cartridges.
  2. Remove the existing printhead by lifting the latch in the center of the carriage. printhead_removal.jpg p342_0064aa.jpg ESP 3, 5, 7, 9, 3250, 5250, 5210,
    ESP Office 6150, 7250, 9250;
    HERO 7.1, 9.1, OFFICE HERO 6.1 ESP 1.2, 3.2, 3.2s, C110, C310, C315,
    ESP Office 2150, 2170;
    HERO 3.1, 5.1
  3. Close the printer access door.
Oct 21, 2014 | Office Equipment & Supplies
Www kodak com go support
We threw our 6150 into the trash (Florida does not recycle electronics) because it would not print correctly, even after we installed a new printhead and all new cartridges.
I recommend you cut your losses.
Aug 02, 2014 | Kodak ESP Office 6150 All-in-One Printer
Why scanner is not scanning.
The very first thing to diagnose such issues is: make sure if your printer is communicating with your computer and you are able to print at least. You can try to copy some stuffs to make sure the printer/scanner is functioning fine and it's causing issues with computer. You should installed the updated driver/firmware as well.
KODAK ESP Office 6150 All in One Printer Firmware WINDOWS Operating...
Windows 8 1 compatibility for Kodak ESP 7 All in One Printer model...
Jun 24, 2014 | Kodak ESP Office 6150 All-in-One Printer
Kodak esp office 6150 printing blank pages
Here's how I fixed my Kodak AIO 6150.
  1. 1. Remove cartridges
  2. 2. Remove the print head - lift up on the grey tab just above the bullseye - it'll pop right out - no tools needed.
  3. 3. Soak in alcohol - NOT RUBBING alcohol - Isopropyl 91% only for 1-2 hours - shake often.
  4. 4. Let it dry for at least 2-3 hours.
  5. 5. Reinstall everything. You'll get a new printhead message.
Dec 07, 2012 | Kodak ESP Office 6150 All-in-One Printer
How do I clean the ink heads of the ESP3250PP ALL-IN-ONE
For ESP 3250, 5250, 5210, Office 2150, 2170, 6150, 7250, 9250, C110, C310, and C315 printers:
  1. Press Home on the printer control panel.
  2. Press the down arrow button until Maintenance is selected, then press OK.
  3. Press the down arrow until Clean Printhead is selected, then press OK.
Thanks!!
EJ Kudelka
May 29, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Kodak esp 5 not printing properly and no yellow
Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy.
Dec 17, 2009 | Kodak ESP 5 Printer
Printout is faded lines running through the text on a new ESP 5
Try cleaning the Printhead by pressing the Menu then clean Printhead
Try reseating the inks
Try reseating the printhead (for instruction on how to remove the Printhead visit www.kodak.com/go/printheadsupport)
If the above steps didn't resolve the problem call 1800 421 6699 they will replace the Printhead for you
Aug 21, 2009 | Kodak ESP 5 Printer
Screen showing replace printhead and cartidges - which i have done - still not working
try to reseat printhead . you can refer to www.kodak.com/go/printheadsupport on how to install the Printhead properly. still issue persists,Kodak will replace the printhead or printer for you free of cost as esp series printers are under warranty.
Jul 08, 2009 | Kodak ESP 5 Printer
Its saying paper jam when iv only just installed it and i have not evan put any paer in yet. help me please this is a kodak esp.3
It means it has "paper jam"error message. This is a common issue w/ the ESP printers of Kodak especially if its brand new.
Try the steps below.
1.Open the printer access door.
2.Remove the black and color ink cartridges.
3.Reseat the printhead.
a. Lift the printhead release latch
b. Reseat the printhead, pushing firmly on the white label on the printhead (if provided) or the center of the printhead, until it clicks into place.
NOTE: You may also visit www.kodak.com/go/printheadsupport for demonstration on reintalling the printhead
4. Close the access door.
5. wait for the printer to initialize.
If issue persists, the printer itself needs to be replaced. Call 1.800.421.6699
Thanks
Neerak21
Jul 05, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Open Questions:
137 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
