SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Hi - Typically error code E08 on Electrolux models indicates that it is recommended for a professional to check the mist value on the motor. Try resetting the unit by unplugging it or flipping the breaker to the household circuit breaker. Wait approximately ten minutes and turn on the dryer. If the error code does not clear and it is ineffective, contact a professional to move forward accurately.
Hi Nora King - Error code E70, typically means that there is a communication error with the outlet/inlet control thermistor that has an open or short circuit. You will need a certified professional to check the resistance of outlet/inlet control thermistor and check wiring for either short or open circuit.
