Hi.you have not said what windows you have,but try this.Follow these steps to disable the Automatically restart option: In Windows, search for and open View advanced system settings. Click Settings in the Startup and Recovery section. ... Remove the check mark next to Automatically restart under System Failure, then click OK. ... Restart the computer. Or this link..https://support.hp.com/ph-
en/document/c03413399. Or this one...https://www.google.co.uk/search?q=My+Lap...Hi.you have not said what windows you have,but try this.Follow these steps to disable the Automatically restart option:
Or this link...https://support.hp.com/ph-
Or this one....https://www.google.co.uk/search?q=My+Laptop+take+auto+restart&rlz=1C1CHBD_en-GBGB719GB719&oq=My+Laptop+take+auto+restart&aqs=chrome..69i57j0j69i60.1164j0j8&sourceid=chrome&ie=UTF-8
You can't post conmments that contain an email address.
Solved: Laptop Keyboard Not Working
27 MARCH, 2014 BY JAY BOKHIRIA17 COMMENTSMy Laptop Keyboard Not Working? Here I solve HP, Dell, Lenovo, Toshiba, Acer, Asus, Samsung, Sony, etc., laptop keyboard not working. This question is asked by peter and last few days I was working on this issue. There are many factors are related to this issue. So after lot's of hard working I was found some tips and tricks to solve laptop keyboard problem. Laptop keyboard is attached with high complexity, so we don't open it by self and repair it, but there is no problem with your hardware because as I said above there are many factors related to this issue. So here I give you some tips and experiments that I used by self and it's working on many laptops, so follow tips one by one.
How To Fix Laptop Keyboard Not Working
Tip 1:
Reboot (Restart) your laptop because Restart solve many problems instantly. So first Restart your laptop and check keyboard working or not, if not working then follow tip 2.
Tip 2:
Restore your system: System Restore is the best way to solve keyboard software problems. If your keyboard not working after install Unknown Software then this trick is working for you. If not working, then follow Tip 3.
Best Keyboard: Best Gaming Keyboard 2015
Tip 3:
Check Your Drivers are up to date or not. If not, then update drivers first and then restart and check your keyboard working or not.
Also Check: 20 Windows Keyboard Shortcuts
Tip 4:
After update keyboard drivers and still your keyboard not working, then follow the simple steps.
Step 1:
Open Run and type "devmgmt.msc" then enter to open device manager or Type "Device Manager" in search and open Device Manager.
Step 2:
In Device Manager finds Keyboard and then right click on Keyboard device and click Scan for hardware changes. Watch below video for better understanding.
Watch Video Tutorial Here
Solution 2: Watch Video Here
Conclusion
If This Post Helpful for You, Then Follow Me:
The above steps are working for you if there is Software problem in your laptop. If there is a hardware problem with your keyboard, then contact your technician or Buy New USB Keyboard for your laptop. If you have any other question or queries, then please comment below I will happy to solve your problems.
I enjoy helping people, I don't do it for money. You are not obliged to help anyone if you don't want to, the choice is yours... If you want to get paid for your advice, google 6ya
It seems that your profile got corrupt, simply login from the administrator account of your computer,
You can solve the issue by procedure below
go to my computer>users>your profile> and copy all of your required data including outlook data if you are using to external drive or other partition (e.g D Drive)
then delete the profile folder from your laptop from c:\users\your profile
restart your laptop and try to login again from your username/password, if it stills give the problem,
Login via administrator account, go to Start>run> and type
control userpasswords2 and press enter, here you will see your profile, simply delete your profile and restart again, when the computer boots up again it should show you your profile if not again login via administrator account and recreate your profile and restart your laptop
after you login to your account, simply copy your data back to its location
if you require more assistance feel free to reply to this post
Regards,
Bilal
hi rayson, i can understand your problem, may be this because your cooling system is not working properly , on that time your laptop getting restarted check back side of laptop how the heat is, if its more heat mean, your cooling fan is not working properly better use laptop stand so that air can go freely bottom side. or else you have problem in OS , may be your OS got corrupted try to reinstall the OS and check it, you can find the solution for your problem. Good Luck!
Reboot is the term for shutting your laptop off and restarting it. as apposed to leaving your laptop running or in standby at all times. The easiest way to restart is go to the Apple
Menu in the top left corner and selecting Restart. You will be asked if
you really want to restart.
The other way is to push the power button once and it will bring up the window asking if you want to shut down or restart.
