Question about Kenmore Elite HE4 Electric Dryer
I need a manual for an electra reversair eco dryer spec no 37472E
Posted by Lana Mccartney on
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Bought "Electrolux eco turbo lava
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
2answers
I have a creda reversair anti tangle dryer and dont understand the heat setting button on the front, is it pressed down at the top for low or at the bottom as there is a green line shows if its pressed...
The issue isn't a "problem" with the dryer, the issue is that it's hard to tell which switch position enables the 'low heat' function. The question is:
Is the switch pressed in at the top or the bottom for 'Low Heat'?
Feb 18, 2011 • Dryers
My creda reversair dryer no.37642 doesn't rotate, although there is heat in the drum. What could be wrong with it?
Most likely the drum belt is broken or the tensioner is broken this is not to expensive to fix and the belt can be bought at any applince store.
I need to recall the system speed dial directory on my NEC Electra telephone system. I am unable to find a memory re-call/display feature in my manual.
With this old model of phone you don't have the soft keys to scroll through the directory like the newer models have.
In order to check the system speed dials you will need to check them manually:
System Speed Dial #'s
LNR/SPD key and the system speed # 00~79
Station Speed Dial #'s
LNR/SPD key and the system speed # 80~99
This will dial the # and/or display the name associated with the speed dial.
In order to program them refer to this manual:
Elite IPK Features and Specs
Look under Speed dial-Station or System.
Change belt on electra 37527
Hi what you need to do is take front off the dryer take out old belt the new belt is then placed around the drum around the drive wheel and then under tention pully . thank you for useing fixya
RATE ME
Apr 15, 2009 • Dryers
6helpful
Creda Reversair Sensa Dry Tumble Dryer produces no heat.
There is only 1 heater element, and normally one thermostat.
they are located at the rear of the m/c, behind a removable panel.
If you are not sure whether it is the element or stat, join the two
wires togeher that go to the stat, if the heater then works, replace stat. if no heat, replace heater.
plz leave feed back for this solution.
Thanks.
Dec 17, 2008 • Dryers
Open Questions:
See all Kenmore Elite HE4 Electric Dryer Questions
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
