SOURCE: canon ir 8500
E010 relates to a main motor fault. A specified amount of rotations has not occurred within a set time. Check motor, see if it turns by hand. If not, inspect and/or replace. Check belts and gears for wear/damage, replace as necessary. E065 relates to a primary charging problem. Suspect primary corona arcing, corona wire broken, High-Voltage PSU may be unservicable, black developer unit may be pulling HVT down. How many copies has each machine done? Recommend calling an engineer, parts are probably required.
SOURCE: ERROR IN IR 8500
eo 732 is a reader board error or a bad or missing connector from the scanner to the machine looks like a parrallel connector
SOURCE: canon ir 8500 error code 001-010 and E 001-003
You can start by downloading this software, a new driver dated April 7, 2009
canon driver for the ir 8500
SOURCE: i have one copiar machin
Sc101 is a scanner home sensor error. Try removing the exposure glass, and clean the WHITE STRIP on the underside of the glass. If that does not work, there is a mechanical problem with the scanner such as a broken drive cable, which will require a trained technician to repair.
SOURCE: ir 8500 cannnon copier black shade on paper
hi dude i dont think u have problem with drum cleaning blade coz it not making trouble for me from last 5years.
just replace the crona wires both charge and transfer and clean the whole scanner mirors .
thanks
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
