Question about Miele Cooktops
SOURCE: Miele KM5753 Induction Cooktop - Error 30
I have a KM5753 with FE31 and it remains after a breaker 1 minute re-set as per instruction booklet - anyone seen that one?
Posted on Sep 22, 2008
SOURCE: Wolf electric induction stovetop
We had the same problem with the Wolf induction stovetop. They came out and changed out a part and have never had that problem again. They said there was a problem on all units that came out earlier this year (2008) so if you are one of those, you should call them and have them change that out. But... I am also very frustrated about the inability to fry things on this unit. I don't fry very oftehn but it gives very unsatisfactory results, constantly shutting the heat off and then back on. Hmmm yumm.... soggy rare ahi- uncrispy chicken- anybody?? HELP!
Posted on Nov 25, 2008
SOURCE: i have a miele gas
Hi, well whenever this happens, it is usually unrecoverable, IF one immediately attended to the matter, and, stopped, Dried out,and sealed up the ingress points, one may be able to stop the problem from happening,
However once water, moisture, liquid, gains entry into the internal core of the Cook-Top, it migrates everywhere throughout by capillary action, this then provides a high resistance path between Earth/Neutral and Phase, this then "Blows" the Fuses.
IF one could find a way to completely dry the Cook-Top out, by say heating for a time in an "Oven" or the like and one could drive out the moisture, then one maybe able to recover the cook-top... otherwise it will continue to blow the fuses as there is always going to be a current path through the moisture to earth.
Posted on Nov 25, 2010
SOURCE: Using a Berlin induction electric stovetop - I
Dear friend,
im sure if you go to the AEG website & type your modle # etc, you would most probably find a downloadable user manual for that. Give it a go.
Cheers
Jim.S.
Posted on Dec 27, 2010
