Question about Turbo Air Refrigerators
Turbo air model msf-49nm f2 error flashing
Unit runs for a really long time and when turned of it takes over 4 hrs to kick back on fans on the evaporator coil run but no compressor and no fan on condensing unit
Posted by Anjeza Kola on
5 Related Answers
Anonymous
  • 143 Answers
SOURCE: GE Central A/C Unit about 30 yrs old; condenser fan stops after a short time.
I gather that it is the outdoor fan motor that runs a bit then stops.
Fan motors that stop by themselves are overheating and going into self-protect. The fact that you replaced the motor and capacitor opens up a whole world of "which wire is in the wrong place". I could do this if I could see it, but I can't see it. You're probably going to wind up calling a service man to sort out the wiring.
Posted on Jul 25, 2008
peyton32034
peyton thompson
  • 410 Answers
SOURCE: Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Posted on Jan 20, 2009
SOURCE: Evaporator fan did not start running when condenser fan started.
I don't know why there would be much of a delay between the condenser and evaporator fans coming on. If you have diagnosed it as a bad motor, that's probably correct.
But the motor could just need cleaning and lubricating
Posted on Apr 28, 2009
Anonymous
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
Anonymous
  • 534 Answers
SOURCE: Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Posted on Aug 04, 2009
Testimonial: "Yes, it's dual run capacitor problem. I used a stick to spin the fan blades and it starts to slowly spin and up to normal speed, so motor is good."
I have a Kenmore Elite model no is 59673502201 and it stop cooling in both the frig and freezer i replaced the condenser fan motor and it worked so i replaced the back and the unit will STILL NOT GET
Do you hear your evaporator fan running in the freezer drawer area?
If not, then that's the fan you should have replaced.
If your compressor is running and both the compressor fan and the evaporator fan are running, check the back wall of your freezer compartment. If it is frosted up, then you have a defrost problem.
If it's not frosting up, disassemble your freezer drawer section and remove the back panel in the freezer to look at your evaporator coil.
If it's partially frosted at the top, or bottom, but the rest of it is dry looking, then you've got a leaking sealed system.
If it's lightly frosted all over, then you have good coolant flow and you need to start looking at your thermostat and damper up in the fresh foods section.
Nov 10, 2014 | Kenmore Refrigerators
The fan on my GT345 chest freezer runs constantly. Is this correct ?
Depends are you referring to the condenser fan or the evaporation fan? If it's the condenser fan you may have an issue with debris in the condenser coil not letting enough air flow to cool down so it will stay on to keep from burning up compressor.If it's inside the evaporator coil then it may be low on refrigerant possibly freezing up the evap coil making it run then kick into defrost run kick into defrost etc... hope this helps
Aug 12, 2014 | Freezers
Rangemaster sxs cream . Why is my fridge and freezer the same temp ???? If anybody could give me an answer or solution.
Jason,
MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped. 3. Your condensing unit:(compressor, condenser fan, condenser coils) has a problem.
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 11, 2013 | Refrigerators
Undercounter Frigidare 4.4 cu.ft. sudenly stopped cooling. Still has slight vibration as before and compressor warm to touch. Starting capacitor shows 26 ohms restistance.
The compressor seems to be running since it's warm. If it is functioning properly the two lines(pipes) running into it one will be warm and the other cold.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jul 04, 2011 | Frigidaire Refrigerators
The fridge is working whit out stop
If the unit is running all the time and is not freezing everything then open the back fiberboard panel and clean out the coils in the back. Check to make sure the condenser cooling fan is running also. If the compressor is running and the condenser fan is not running there is a problem with the condenser fan. The compressor, condenser and evaporator fans all should be running at the same time. the condenser fan can be stuck... have dry bearings... of simply has failed. Before removing the back cover... touch the chassis were the doors close... it should be warm but not VERY warm to the touch. If it is VERY warm to the touch... for sure you have a problem with the condensor fan.
Since you did not say anything other than the fridge is working whit out stop, I have to assume at this point that the evaporator fan is running in the freezer compartment just fine.
I really need to know:
1. Is there ice in the back of the freezer compartment?
2. Is the evaporator fan running?
3. Is the condenser fan running?
4. Are the condenser coils clean?
One of the above has a problem... you just need to identify which one.
Thanks for choosing FixYa,
Kelly
May 14, 2011 | Sharp Refrigerators
Kenmore refrigerator model 59562998 Compressor is running but no air is blowing into the refrigerator or freezer
the evaporator fan has stopped. it is usually in the back of the freezing compartment behind all the plastic. when the fan stops no air can circulate over the cooling coils so even though the compressor is running no cold can move iside the freezer or fridge. be extra careful when you take the small screws out as the screw heads can be full of build up that makes it hard to get a good hold of them. take your time and clean off all the screw heads so they don't strip out. The evaporator fan is not to expensive wait to buy on until you get the old one out.
May 01, 2011 | Refrigerators
Compressor runs for a short period of time then kicks off, compressor fan is good. interior condensing coil fan runs well. temp is between 43.3F - 45.0F. Fins are clean on compressor. dial is set at 9,...
1 is freezer side ok?if it ok. it is easy. air vents blocked in either compartment.remove any objects from in front of the air vents.
2 evapor fan work ok.
3 how much frosts build up the evapor coil, if it build up to blockthe air vent. mayon the back wall of the rfrigerator self-defrost timer or deforst thermostat is bad
if it still not work. i have to see hat i an do for u. my e-mail is [email protected]
Jan 11, 2011 | True T23 Refrigerator
My side by side is hot between doors. vaccuumed coils
Gas in the system is warm, check that the condenser is not blocked up with dust...either on back of fridge or will be on front at bottom behind kick strip. aslo make sure the cooling fan running when compressor running, if a fan is fitted. not 100% sure of this model
Jan 01, 2011 | Amana ABB1927DE Bottom Freezer...
The refrigerator has quit working. Lights come on and fan appears to be running. Not cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Oct 12, 2010 | Maytag MSD2756G Side by Side Refrigerator
Fans inside freezer will not turn - no cooling - compressor fan underneath is turning
The fans are controlled with a clixon that has a cut in at 5 degrees, and cut out at 20 degrees. If the unit is running and the fans are not comng on then I would have to say you are out of freon. But your condensor fan could be running and the compressor NOT be running which could be a problem with your compressor. Find out if your compressor is running by taking an amp draw. If compressor IS running then you are low on freon. If the compressor is running and your evaporator coil is cold and your fans AREN'T coming on then your clixon is bad.
Sep 26, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Refrigerators Logo
77 people viewed this question
Top Turbo Air Refrigerators Experts
Dennis Boxerman
peter gittos
peter gittos
Lawrence Oravetz
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
