Question about Speed Washing Machines
Speed Error Code Ed24. What is it. Machine is new
Posted by Mary on
Error code CO3FF in konica minolta 215 pls help me to solve it
Enter service mode go to adjust, select correct machine 23/21/19 pages per! some one chg this setting one part of the machine thinks it one speed the other a different speed
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 25, 2017 | Konica Minolta Office Equipment & Supplies
F6 error code whirpool duet
The F6 error code for this model indicates a drive motor tachometer error. The control board is unable to properly detect the motor speed.
Jan 09, 2016 | Washing Machines
Treadclimber error code H-23
Answer from bowflex service line. H 23 means "no tac signal". which means, a signal cable is loose or disconnected. OR the motor needs replacing...estimated cost $350 Canadian.
Apr 01, 2014 | Exercise & Fitness
F6 error on Hitachi washing machine Sk 120KJS
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires.
Jul 09, 2012 | Washing Machines
Got an F4 error message on a Dacor dishwasher model ED 24. Is it a drainage problem? How do I fix it?
Hi. The F4 is a drainage problem. Clean out the hose(s) and try again. It also could be the pump is not pumping due to the blockage. Try back washing the hose(s)
Jul 18, 2011 | Dacor ED24 Built-in Dishwasher
LG Tromm washer wont spin through the spin cycle and reads error ue. I have tried to balance the load several times and still get the same error.
This error generally happens when people try to run a bulky load, like a coat, rug, pillow, etc., using a high speed spin. For these loads, choose the low speed spin. After the cycle completes, if you think the clothes are too wet, power up the machine again but instead of choosing a cycle, just push the spin speed button until it shows the next higher spin speed (usually about 14 minutes will show on the display) and push start. The machine will usually be able to get to a faster speed now, as the clothes have some of the water spun out of them from the earlier low speed spin, allowing the machine to reach a higher spin speed without the Unbalance Error code showing up. Of course, you want to make sure the machine is on a solid floor with all the legs adjusted properly also.
Jan 02, 2011 | LG WM-1832C Front Load Washer
I need assistance with fax error codes # 322 and # 358. What do they mean?
Error code 322- There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
Set the receiving machine to receive at a slower transmission speed
If the session fails after sending several pages of a large document, resend the document as several smaller documents.
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Error code 358--
The remote user pressed the Stop key,
The remote machine encountered a system problem such as no paper or a paper jam.
Try
Configure the local fax machine to use a slower reception speed.
Disable ECM mode on your machine.
Try sending a fax to another location.
Mar 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Why the dish washer said f6 floor guard
f6 is a fault code . this dishwsher is self diagnosing / inside the control panel you will find a tec sheet with a list of codes .. you will the know the failure . such as a float problem . no drain / no fill ect .. for more info i need to know model # hope this will help m.m
Apr 17, 2009 | Dacor ED24 Built-in Dishwasher
Error code
What exactly is it doing out of the ordinary?
Jan 28, 2008 | Dacor ED24 Built-in Dishwasher
Washing Machines Logo
325 people viewed this question
Top Speed Washing Machines Experts
Marvin
Marvin
Vernon Taylor
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
