Question about Sylvania Televison & Video
SOURCE: DVD player won't play certain movies
it could be the disc that is causing the problem try some other disc and see what it does.good luck.
Posted on Mar 23, 2007
SOURCE: DVD player reads open and the when I push the play button it reads invalid key
I am having the same issue with Toshiba SD-P1850
Posted on Dec 26, 2007
SOURCE: stuck in 'set 1'
Had this same problem and found the solution elsewhere on the net. Hold down the "1" button and the "Enter" button for aprox 10 seconds while pointing at the player. This "resets" the remote. I was skeptical when I first read this solution but it worked for me!
Posted on Jan 22, 2008
SOURCE: DVD player reloads after 5 minutes into the movie
I have a K715 that was having the same problem. The "line select" had been switched from "in" instead of "out". Once I switched it back to "out", the player worked normal.
Posted on May 12, 2008
SOURCE: dvd "unknown disc" message coming up
When Your DVD shows "LOADING" for quite some time and then if shows "UNKNOWN DISC" or "NO DISC", Open the cover of your DVD Player, Remove the flap over the disc by opening the screws. Remember that you are not keeping your eyes perpendicular to the lens. Now take Colin liquid in an ear buds and rub over the lens. Now with dry end of the bud, rinse it and make it dry. Keep the disc in the space provided for. Put on the Flap over the disc. And try to run it. I hope this would work fine.
Posted on Jul 13, 2009
Aug 19, 2014 | Televison & Video
Oct 22, 2012 | Sylvania Televison & Video
May 27, 2011 | Sylvania SDVD1023 Player
Jul 30, 2010 | Coby TF-DVD7100 Portable DVD Player
Oct 23, 2009 | Durabrand PDV-709
Feb 04, 2008 | Sylvania SSD803 DVD Player/VCR
Jan 18, 2008 | Sylvania DVC850C DVD Player/VCR
Mar 06, 2007 | Power Acoustik PADVD-150 Car DVD Player
Nov 18, 2006 | Sylvania (SRDD495) DVD Player/VCR
173 people viewed this question
