Cameras Logo
Question about Nikon Cameras
Where to get a shutter button for nikon coolpix l105,lost mine off
Is shutter button , zoom cover easy to replace once i can buy one?
Posted by doriscamp44 on
Steve Alexander
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • Nikon Expert
  • 165 Answers
Nikon has done what many companies have done. Taken parts off their website. This means you cannot BUY anything but accessories. This forces you to send it to a Nikon Certified Service Center where they'll QUOTE the job before repairing it. If you send a camera in always ask about cleaning it too. (if it is old).
Posted on Jun 02, 2018
5 Related Answers
Anonymous
SOURCE: Nikon coolpix 2200 zoom
Based on your description, it certainly sounds like the zoom button is stuck or shorted. If you're comfortable with taking it apart, I'd try getting to the zoom electronics and see if there's any noticeable damage. Whenever I try something like this, I like to see how much damage I could cause first. eBay has sold this item for less than $50 with shipping (just in case you break something). You can also look there for parts cameras -- one listed for $10 with free shipping that might give you what you need.
Posted on Aug 21, 2007
Anonymous
SOURCE: Samsung Maxima 105 zoom
I have the manual. I'll scan it for you & email it. My problem is that the manual doesn't identify the batteries & I lost the ones I'd removed for storage.
Posted on Feb 24, 2009
Anonymous
SOURCE: The latch on the battery door of my Nikon Coolpix
How do you replace the battery door on the Nikon Coolpix L!?
Posted on Jan 30, 2010
Anonymous
SOURCE: I have a Nikon S600 Coolpix. The Mode Button does
I have the same problem. Nikon told me to remove the battery and digital card for 24 hours, then put ONLY the battery back in and try. It didn't work for me, but it is worth a shot.
Posted on Jan 21, 2011
Anonymous
  • 107 Answers
SOURCE: Nikon coolpix S3000 won't take a picture when the
Assuming you have new batteries and the camera lens cover is opening when turned on. Try switching to any mode other than automatic, turn off the flash, and press the shutter button. Many cameras have a safety feature that prevents the flash capacitor from charging if the case is opened. This is to lessen the chance of electric shock. They usually use one or two of the screws along the perimeter of the camera to complete a circuit that lets the processor know that the case is closed. Verify that all the screws are in place along the perimeter of your camera, and that there are no gaps along the perimeter seams. If you're missing a screw, try using one of the others to replace it.
If they're all there, next thing to check is the batteries. The brand that you're using may have reached its shelf life, or just may not have sufficient power to charge the flash capacitor. Try a better brand, or better yet rechargeable NiMH batteries.
If the above didn't help, then the flash tube or its circuit is probably at fault. In this case, would then recommend professional repair. This repair is somewhat difficult, requires some soldering, has some danger of electrical shock, and goes beyond what I'd like to describe here
Posted on Jun 13, 2011
Testimonial: "Many thanks, the camera is fairly new but just out of warranty. I have tried all your suggestions but still no luck. Off to he repair shop!"
I need to get a new shutter button for my nikon coolpix L105 and i cant find any anywhere
Did you say you searched all over well Some things you just have to get from nikon sorry
1helpful
Bracketing with a Nikon L105
Well, in a word, no. However the camera does have exposure compensation (multi function button +/- and adjust the exposure compensation up or down) but the camera is not "smart" enough to give you the + and - effects of auto bracketing found on the more advanced Nikon cameras...I believe the D5100 is the least expensive in the Nikon lineup with feature. Good luck.
After inserting memory card in Nikon coolpix L105 the error 'this card cannot be used' has occured. what is the solution?
The L105 works with SD cards. Make sure you're not using an SDHC card. You need to use SD cards, 2GB and smaller.
7helpful
2answers
How do I dissasemble nikon L105
You don't! That is a job for a qualified camera repair man. Trust me. I know what I am talking about. You will have a pile of parts that you cannot reassemble when you are done and on a Coolpix, the resulting repair bill will mushroom to more then the replacement cost of the camera. Cameras and lenses come apart fairly easily, but often cannot be reassembled by following a simple reverse order of the process.
Nikon Coolpix L105 Camera won't read a memory card
Your camers is set that way change your settings go to menu
Nikon coolpix L110 flash blown. how to replace and how much?
a flash bulb is burned, the burning smell came out. L105 is compatible with? which is found in ebay and is similar to a view.
regards
Nikon Coolpix 5700 Over-exposure of image whilst zooming in brigh
I now have the exact same issue. When not zoomed or fully zoomed the exposure is correct, however when partially zoomed the aperture does not engage and stays fully open. So basically I cannot really use the zoom or the picture is over exposed. Note - actually about 2/3 mechanical zoom and on works, so I can use a bit of the zoom.
Suggestions?
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
