I have a kenmore washer model 25102, it was in spin mode and suddenly stopped three red lights lit up on the spin,lid lock, and complete, lights. The I canceled the load and now the sense cycle light just flashes and if you push the start button the sense light just stays on and does nothing else. What is wrong with it? If anyone has a answer please respond.
SOURCE: Kenmore He 2 Plus washer door is locked and unable to open
unplug the washer an the door will open
SOURCE: I have only had this
it most likely under warranty call the place where u bought it and have them to replace it or send a repairman to have it fixed
SOURCE: WTW5550XW0 Whirlpool model Cabrio When
Either the circuit for the locks on the control board is faulty,Or the locks themselves are faulty. From what you are explaining, I would tend to think the board is the problem. As you are able to unplug then the lock will unlock. You need to put the machine through a diagnostic test to determine what error code is showing, and to also test each component. Here is a complete service manual for your machine. Look at page 6-4 for instructions on entering the diagnostics mode.
SOURCE: I have a kenmore model 110 top load washer with
Make sure there is nothing down in hole where plunger goes to lock.
You will need to replace the lid latch assembly. Here is the part to order.
Here is a video to show you how to replace the lid latch.
