Question about Panasonic Televison & Video
My panasonic dmr e50 dosnt seem to have enough power to fire up ,the clock is working and i have a circle going around in black and nothing else help
Posted by Terry demar on
5 Related Answers
Anonymous
SOURCE: Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Posted on Mar 20, 2007
Anonymous
SOURCE: Set Clock Greyed out
I have the same problem - clock set is grayed out. Called Panasonic tech support .. this is the solution I was given. It works, but too bad the root problem can't be fixed (bug ridden unit).
Solution is to "reset" the unit - then go back into the menu system and set the clock. How to reset the unit (don't worry - anything on the HD stays intact):
1) go to DVD mode
2) remove any DVD in player & close tray
3) on front panel, behind door - press & hold BOTH channel up & down keys for 5-10 secdons -- until you see a message that the system is rebooting
4) wait till it reboots, go back in the menu and set the time.
-Craig
Posted on Dec 19, 2007
Anonymous
  • 5 Answers
SOURCE: Out of nowhere, my blackberry bold appears frozen
try 1-3 minutes with battery out. Maybe sim card is loose. Make sure it is tightened.
Posted on Apr 14, 2009
nandosnut
Mike C
  • 112 Answers
SOURCE: panasonic dmr-e55 won't work, just says "hold" on display
HOLD or X HOLD? If the latter - which is most likely - then the Child Lock has been activated! Press and hold ENTER and RETURN simultaneously until HOLD disappears!
Posted on Apr 24, 2009
Anonymous
SOURCE: i have a panasonic DMR-ES46V vcr/dvd HDMI i lost
1) Hold The Enter Button Down On The Remote
2) Press And Hold The Numeric Button "1" For About 3-4 Seconds
3) Your Remote Is Now Reset To The Remote Control Code #1 (Default Setting)
Posted on May 02, 2009
Bubble console code for panasonic dmr e50 dvd recorder
Hi panasonic codes from book are
2017 1990 1986 1925 1909 1910 1908 1907 1905 1762 1490 1462 1362 1011 1010 0824 0703 0632 0503 0490
For bush
1695 1165 1128 1051 1021 0884 0879 0833 0831 0811 0778 0758 0733 0730 0723 0717 0699 0713 0699 0695 0690 0689 0676 0672 0518 0516 1170 1140
These codes are from a book a couple years old but should hopefully work, i only ended up here trying to find codes for mine as theres only one in the book.
1helpful
2answers
hi have seen your plight i have a booklet with codes as panasonic codes 2017 1990 1986 1925 1910 1909 1908 1907 1905 1762 1490 1462 1362 1011 1010 0824 0703 0632 0503 0490 good luck
Panasonic
There is a manual for a E50S and a E50K. Could one of these be yours? One might be close enough to help. Go here
http://www2.panasonic.com/consumer-electronics/support/
DMR-E50 DVD recorder versus DMR-ES15 are these equivalent recorders
The DMR-ES15 is a later model (around 2006/07) than the DMR-E50 (2003/04), but essentially both should do the same job so technically - a good equivalent in terms of recording and same brand so yes. The connections on the rear (of the replacement recorder) should suit and work with your other devices just as the old one did.
According to some other online reviews, the DMR-E50 has had a few issues with recording, and finalizing certain discs.
I'd say go for it - accept the replacement - as long as it comes with some kind of guarantee, works fully and has all the accessories (including remote, instructions etc.) you should be good. Contact the store and seal the deal.
I hope you can get this in time for Christmas.
My display on the dmr-e50 shows ready but will not turn on.
UNPLUG UNIT FROM THE WALL SOCKET & REPLUG AFTER 12 SECONDS.
Remote Controle Problem
You can get a replacement original Panasonic DMR E-50 remote from various suppliers on the net or on eBay - part number is IRC85049. Just google 'Panasonic DMR E-50 remote'
DMR-E50 Region Codes
have been looking for hacks myself but as yet can't find one...
I have seen remote controls for sale on Ebay for this (Converts to multi region at the press of a button) seem to sell at reasonable prices.
Has limited life say around 10 uses.
DVD DMR-E50 Doesn't Work
As it's been 5 months I suspect problem's been solved - how? I have similar problem, E50 recorded DVD-r's lock up after playing about an hour. RAMs and commercial DVDs play fine.
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
