Question about Locks & Locksmithing
I have a defiant electronic deadbolt. It was unlocking but if you try to lock nothing happen
Posted by Tiis pa Anak on
5 Related Answers
short shadey
jeff r
  • 421 Answers
SOURCE: deadbolt mode
put the key in drivers door and unlock all they way to the left -jeff
Posted on Sep 02, 2008
NOT ME
  • 2841 Answers
SOURCE: Deadbolt wont unlock
Remove the deadbolt cover by removing the 2 screws. This will get you inside the deadbolt. Try using a screwdriver to pull it back. You may in the end have to break the unit in order to get it out and replace it. I have the same thing happen with a deadbolt. I ended up having to destroy the unit to get it out. You are going to replace it anyway so do whatever it takes to get it to unlock so you can then remove it from the door and install a new one. You do not want a deadbolt that will not unlock.
Posted on Jan 10, 2010
Anonymous
  • 6 Answers
SOURCE: Kwikset Smart Key Deadbolt Won't Unlock
Kwikset Smart Key locks are complete junk. I am a locksmith and I am constantly going from house to house replacing these "dumb key" locks with original kwikset pin tumbler locks. What happens is either your key or the wafers inside the lock wear slightly, slightly enough to cause your keys to not turn, and since these locks cannot be picked due to a side bar system, they must be drilled off and thrown away when this happens Unless you have another access point to get in the house. If you do remove lock from the inside, throw it in the trash, buy original kwikset and replace.
Posted on Apr 29, 2010
Coaltowner
  • 963 Answers
SOURCE: Just installed keyless entry lock. Lock button
Your lock is under one year warranty, with a lifetime warranty if the problem is mechanical or the finish.
Here is a link to the website warranty information, and from there you can contact them for technical and warranty assistance:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Good luck-and please provide feedback if this helps!
Posted on Nov 05, 2011
Gord Stringer
SOURCE: I bought Rona Collections Electronic Deadbolt. My
You must ensure the deadbolt is in the locked position when attaching the control mechanism. The control mechanism must also be set to the locked position. Turn the manual knob to the left then attach the mechanism (with the batteries) to the flat pin. You can do all of this with the door open, so you can enter the codes. My initial install created the same issue. It worked properly out of the package, so that meant that I screwed something up. You don't need to return the item. Just do a little fault finding.
Posted on Dec 28, 2011
Defiant electronic deadbolt manual
I only saw manual mentioned on suspicious or malicious websites/
Sometimes manuals appear for sale on eBay.com or Amazon.com.
Home Depot could be contacted for a manual, as it is their brand name.
Searching for a youtube video might help you.
Example:
https://www.clipzui.com/video/u3q464q2u3z4p4m4162524.html
Electronic Deadbolt Door Lock Install Defiant clipzui com
Apr 21, 2018 | Locks & Locksmithing
Schlage BE365 - How do I remove the key? It will lock/unlock door but cannot be removed from lock.
Recommend resetting the lock back to factory settings and try reprogramming. Also if you don't hold the latch while turning the key to lock/unlock the door it may not be recognizing the keys inserted and this will keep the key in place. Try that before resetting to factory just make sure you hold latch and turn key until it wont turn anymore.
Dec 01, 2013 | Schlage Camelot Deadbolt Keypad, Satin...
We have a garrison keyless entry deadbolt lock with remote entry. when we press the unlock on remote it locks and when we press the loke button it unlocks. If we press the onlock button on keypad it u
If you remove the inside housing from the door, and look inside on the left hand side of the circuit board, you will find a slot marked "L R".
Slide the switch to the opposite of what it is set for. This will solve the problem.
Jan 14, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Weiser powerbolt worked well for several months but now is not reliable anymore. Changing batteries did not help. It sounds like it is locking but sometimes fails to lock...we cannot trust it anymore
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Good lock or good unlock
Feb 05, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
Weiser keypad deadbolt lock deadbolt does not move when motor runs
Dec 30, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Locks & Locksmithing Logo
883 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
