Question about Jensen Televison & Video
Hi, have a Jensen JE2212led remote. The red power light stays on and flickers. The Batteries are good. Any Ideas. Kathy
Posted by Kathy Olsen on
Tom Chichester
    Top Expert:
  • Jensen Master
  • 55,379 Answers
Your Jensen remote control has failed.
Posted on May 14, 2018
5 Related Answers
wyoed1
Ed Meshechek
  • 211 Answers
SOURCE: Vizio L32 HDTV 10A-remote
Try a new Remote control, and if that doesn't fix the problem, it may be a remote sensor in the set. Hope this helps. Have a great weekend
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
Anonymous
  • 3 Answers
SOURCE: Red light flickers, goes off, no heat
I had a similar failure with my Braun WK600. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettleful's; so far so good!
Oh, and if you take your kettle apart and your house burns down it is not my fault.
Posted on Apr 12, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: Polaroid 26inch lcd tvred standby light on but power wont turn on
You need to open it up and checking the voltages in the power supply sections, you should have 5v (for logic circuits), 12v for sound, 24v for backlight inverter circuits. Look for bad caps with bulging tops in power supply also.
Posted on Jan 12, 2010
Anonymous
SOURCE: The red light stays on
I had this same problem as well. It was after I upgraded the OS I had the issue with my LED red light on constantly. I figured out it was the colorpearl application because it is not compatible with the new 4.5 OS.
Posted on Feb 20, 2010
S. Gontko
  • 142 Answers
SOURCE: solid red light
Have about a 30 second window to replace batteries before all codes are lost and when you put in the new batteries it goes into programing mode. Re-enter codes and try it again. Have the same remote and it has happened to me before.
Posted on Mar 15, 2010
It will not turn on red led light stays on any ideas
Usually if a device is turned off with the remote, you need to turn it back on with the remote. Have you checked the batteries in it?
Mar 16, 2015 | Televison & Video
Hi! My digital box - Matsui DTR-2 has stopped turning on from standby. The red standby light is on, but when I press the on/off button on the remote, the function light only flickers and the standby light...
Initially and assuming there was a momentary power interruption, this it is possible that the system has just a glitch and all it needs is a reset. Unplug from the mains for an hours or so to dissipate any residual power and thereafter try again.
Should this be not corrective, then it is possible that the unit has sustained a hardware fault and therefore would require opening up. Further, it needs familiarity with electronic components and circuitry, use of a DVM and a soldering iron as well as access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable doing a DIY, then perhaps your best bet would be to call it in for service.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 06, 2008 | Televison & Video
LG 42LC2D-UB TIVO Remote Stopped Working
Hi Did you check the batteries,and if they're put in properly.
Make sure you have fresh batteries and not 2 different kinds. then do your codes again. Good luck.
Feb 11, 2014 | LG 42LC2D 42 in. LCD HDTV
Our remote control for our Jensen JE2608 is not responding - we have replaced the batteries but still nothing - it seems the little light does not come on - do i need to replace the remote??
Normally, when the light does not come on and nothing happens, it means that there's a fault connection inside the remote somewhere critical (Meaning a wire is not touching where its supposed to.)
My brother fixed several remotes, but he's an electronic whiz and used a good deal of soldering.
Give the remote a few good taps (smack it on your hand, never hit hard surfaces), and see if it makes its connection again, even for a moment.
Whether or not this is the problem, it sounds like you'll be needing a new remote. I suggest going to walmart or best buy and talking to an employee about remotes and which ones work for which televisions, and then order one for a decent price online.
Sidenote: Make sure that the batteries are in correctly.
Make sure that the springs in the battery compartment are functioning as they should and the batteries aren't sliding around, even a little.
That's all I got. Hope it helps.
Jan 15, 2013 | Jensen Televison & Video
Solid red light
Mar 12, 2010 | DISH Network IR Remote Control
Our son dropped our Jensen Universal Remote, the batteries fell out, I no longer have the manual or code to reprogram it, can you help me. Have replaced batteries, red light is on, just can't get TV to...
Manually turn on the component you want to
program.
Find the three-digit code numbers for the
component brand.
Hold the Device key down until the green
indicator light comes on.
Release the Device key. Within 30 seconds,
enter in the three-digit code number. The light will flash when the right code has been entered.
press the Power key. If the component turns
off, you have found the right code.
Send me a mail get your tv code
Feb 18, 2010 | Jensen JR400 Remote Control
Led light constantly stays on remote rcr4358
First off, put in brand new batteries. Not just batteries that are kind of new, i mean BRAND SPANKING NEW batteries right out of the packet.
If you still have a problem:
~hold down the DVD-VCR button-> the red led will stay lit.
~holding down the DVD-VCR button press the number 2 --> the red led will turn off
~Release the DVD-VCR button--> the red led blinks 4 times and turns off.
Hope that helps!
Rate me!
Feb 11, 2009 | RCA Universal Remote Control
Wont power up, blue lights stay on have changed out the batteries
try resetting the remote and the console. in the console you open front panel and their is a red reset button press this firmly then remove batteries from back of remote press the reset on the console again. Then replace the batteries press the red reset on the console a third time and then push the red reset button on the back of the wii remote this should take care jof your problem.
Nov 14, 2008 | Nintendo Guitar Hero Wireless Guitar - Wii...
Programing universal remote
Turn the TV ON. You can use the code search option by pressing Code until the LED flashes. Press the Power button until the TV turns off. Then press Enter.
Jan 20, 2008 | Televison & Video
Televison & Video Logo
119 people viewed this question
Top Jensen Televison & Video Experts
Christopher Stearns
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
