Cameras Logo
G
Gareth Bonner Posted on May 14, 2018
After formatting the memory cards in the laptop they do not work in my panasonic and the camera will not format them
5 Related Answers
Anonymous
  • Posted on Nov 14, 2007
SOURCE: Memory Card Format Fail
Never format a memory card using windows. Always use the camera to format it.
In genereal though, cards do not need formating before use, the camera will sort this out for you
Anonymous
  • 4 Answers
  • Posted on Feb 03, 2009
SOURCE: won't read memory card
i hvae had this happen many times... ok this is what you will need to do. take the memory card out and look at the little brass things and clean them with something thats cotton. repeat this till it reads. i hope this will help.
Anonymous
  • 5 Answers
  • Posted on Feb 13, 2009
SOURCE: cannot format my new memory card
see my solution at:
http://www.fixya.com/support/t389265-wrong_format_hp_m425
posted on Oct 10, 2008
Hope this helps
Anonymous
  • 4090 Answers
  • Posted on Sep 21, 2009
SOURCE: memory card cannot read!!!
sometimes lapstops and PCS as well as Cameras can go out of line. That is the formatting in a particular PC may not be able to be read in another.
In you case this may not be so, as the card now cannot be seen. It would have been interesting to see if it could have read it before it was formatted by your laptop. Try another card in the camera first. If no other card can be read then the problem is on the read head of the camera.
This may be just dirt or damage, and it will have to be repaired. But try another card first as the card is cheaper than a repair.
Thanlks for using FIXYA
Anonymous
  • Posted on Oct 25, 2009
SOURCE: camera will not format 4 gig card
I am having the same problem. I phoned a camera store and they said the camera is too to accept a 4GB card may only accept to a 2 Hope this helps
1helpful
2answers
How do i format an sd card for my panasonic lumix dmc-tz40?
I have got a Panasonic DMC TZ70 I could not find out using the manual how to format the memory card. I discovered how .. set the mode dial at the top of the camera to MANUAL, then select menu then you can keep arrowing down until you find FORMAT, click yes and it's done.
My panasonic camera DMC-F27 is showing "memory
Hi pblac11,
This could be a problem with the format of the memory card , or the memory card is not formatted as per the requirements of your camera.
I would give you a way out to try and see if it works , as I have been through this problem myself too.
Using a card reader device , connect your memory card to your computer and make sure it gets detected in your computer.
In case you are using windows xp , vista or windows 7 , you will find the removable drive relevant to your memory card being detected.
Now all you have to do is try and format the card in a mode that is different than the current one.
For e.g if your memory card has been formatted by NTFS file system , then try changing the format to the FAT32 file system.
and if it's FAT32 already , try formatting the card with the NTFS system and then try and insert the card in your camera after it has been formatted successfully.
The above solution has helped me , hope it helps you as well..:)
Your feed back would be appreciated.
Not a problem, but how do I delete ALL the pictures? I've lost my manual.
You can delete all the pictures on the memory card by formatting it. The memory card should be formatted each time you finish downloading pictures from it---FixYa is full of people asking why their memory cards don't work because they didn't format their cards regularly.
You can download the manual from the manufacturer's web site at
http://www2.panasonic.com/consumer-electronics/support/Lumix-Digital-Cameras/model.DMC-TZ1K
The formatting instructions are on page 91.
When I turn on my DMC LZ10 and try to take a picture (on any setting) I get message: "Memory card full" - I have three good memory cards that work in other cameras and they are unlocked- but...
I've gone into the owners manual for your camera and respectfully disagree with Panasonic's faults idea that you don't have to format the media card. Formatting the camera SD memory card is what you need to do. Any new memory card or any memory card that has been cleaned (formatted) in a computer or used in another camera must be formatted. I fully believe that if you format the memory card you are attempting to use your problem will end. I've done a screen shot here to show you what icon you need to find to perform this formatting.
This will solve your problem
New 4 g memory card says memory card error
I hope you have this problem solved but if not here are some solutions. First format the card as all new memory cards need to be formatted to the camera they are being used in. I'm not totally familiar with the model of camera you have but, if it has been working with say a 1gig card and you then install a 2gig card the camera may not accept a 2gig memory card. In this case you would need to go onto Panasonic's web site and download the updated firmware for your camera. In short if the memory card won't format then it's possible it's to big for the camera until you update the firmware
2helpful
2answers
Hi: I have a lumix/Panasonic DMC-FS3. I keep getting a message "Memory Card Error. Please check the card." Nothing has happened to the card. What could cause that?
Has the memory card ever worked in this camera? If yes, try downloading all the pictures to your computer then format the memory card using the camera setip menu. If this is a new camera, Make sure the camera can use the SD HC type memory cards. Some older cameras cannot read the SDHC but are fine with the SD cards.
Panasonic Lumix will not read memory card.
try formatting your cd card in your Fz. If it keeps telling you memory error, try using it in windows, put data on it, to see wether it can hold them and read them too.
Happeded to me once too, format did the job. Just format it in the camera, not your pc.
Vladimir
2answers
SD card - memeory card parameter error
Some camera's, especially older ones, have a limit as to the maximum size of the memory card that they support. Look in the manual to see what the camera can support.
Just bought a 16 gb memory card for my panasonic lumix tz5- when i inserted it , it says memory card parameter error- this camera is supposed to be able to take a 16 gb memory card, but it wont. works...
Try formatting the card.
As I am not familiar with the Panasonic cameras, nor did you say what card type you were using, I cannot give specifics on what to format it to (if using a computer) or how to do it through the camera, which may have an error and not recognize the card due to a lack of proper formatting, and thus may not allow you to access the card at all, even to format, or if your camera is able to format the card at all.
Specifying what brand and model of card you are using would help.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
