Question about Kodak Office Equipment & Supplies
Will the 600 and the 600H Kodak Carousel projectors accomodate the same slide trays?
Posted by bill thomas on
Marvin
    Top Expert:
  • Kodak Master
  • 85,239 Answers
Slide trays are all the same for all Kodak slide projectors
Posted on May 14, 2018
5 Related Answers
Anonymous
SOURCE: Kodak Carousel 760H wont advance or reverse
Yeah. I like the $15 fix better. Go to Ebay and search for "Kodak Carousel Projector Advance Repair Kit". Before you purchase you can diagnose, and it comes with detailed instructions. The same guy also has a kits for other common problems, as well as the "tune up kit". Or you can buy the Solenoid Link, directly and try it without detailed instructions.
Posted on May 22, 2009
Anonymous
SOURCE: My Kodak Carousel 750H slide projector will not
A common cause for that problem is a broken plastic "link" on the solenoid (Kodak part #217769). There are repair shops who can replace this part. It is very difficult to replace by yourself. http://www.kodak.com/global/en/service/repair/slideProj/index.jhtml
Posted on Nov 11, 2009
Jim Auburn
  • 412 Answers
SOURCE: I'm having a problem loading a tray onto my kodak
First, with the tray off the projector, cycle the projector several times in forward and then in reverse. Next, check to make sure the locking ring on the top on the slide tray is LOCKED ON TIGHT. Then turn the tray upside down. On a 140 Slide tray there is an index notch. On the metal plate there is a index hole. Gently release the metal spring of the tray latch and rotate the metal plate until the notch and hole line up. Now the tray should drop on the projector and index properly.
Posted on Dec 03, 2010
Jim Auburn
  • 412 Answers
SOURCE: I just purchased an older Kodak slide projector
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
Posted on Dec 30, 2010
Jim Auburn
  • 412 Answers
SOURCE: properly loading the slide tray
If the first slide is visable and consecutive slides are not, the "dark shutter" (a feature that prevents the eye-popping bright white screen when no slide is present) needs adjustment. A fairly easy adjustment for a factory-trained service dealer with the service manual and the correct tools.
Posted on Jan 04, 2011
Lift gate tray
No. The slide tray should rotate when the forward or reverse buttons are pushed. Slides are not required for correct actuation of the tray. Before attempting any adjustment, try a few different trays (it may be a tray issue!). A 140-slide tray will be much tougher to get correct movement from than with a 80-slide tray on an older slide projector.... The 140 tray pushes the interface specification between a tray & a projector to the max.
Oct 13, 2013 | Kodak Carousel 4400 Slide Projector
Kodak 140 slide carousel trays jam
The 140 tray with older slides and an older projector is a gamble with slide jams every time!! Slides have a natural curve that gets bigger over time. In addition, as slides age, the corners will begin to de-laminate (aka: "dog-eared" slide). Because the slide slot in a 140-tray is SO NARROW, the least little deformation of the slide from normal will cause the slides not to drop. My recommendation, given the age of the projector, trays and slides, is to get rid of those 140 trays and stick with 80-slide trays. Good Luck !! Jim
Sep 16, 2013 | Kodak Carousel 4400 Slide Projector
Kodak Carousel 600 Slide Projector manual
The KODAK Carousel 600 Projector has NO forward or reverse controls. To cycle the tray forward, LIGHTLY depress the SELECT bar. Reverse is accomplished by holding the SELECT bar down completely and rotating the tray by hand. Jim
Apr 03, 2013 | Kodak Carousel 600 Slide Projector
Kodak 600 projector has not advance button
You're correct!! The Kodak Carousel 600 does not have an ADVANCE button. To advance the tray you LIGHTLY depress the SELECT bar on the edge of the projector. There is no reverse capability, other than holding the SELECT bar down fully and rotating the tray by hand. Enjoy your projector!! Jim
Mar 09, 2013 | Kodak Carousel 600 Slide Projector
Will slides back from 1960 work in a Kodak Carousel Slide Projector?
As long as the slide film is in 2"x2" mounts, yes! I would advise you to use an 80-slide tray as opposed to a 140-slide tray. The individual slide compartments in an 80-slide tray are wider, making it more forgiving to older, possibly warped slides. 80-slide trays can still be purchased from: www.vinevalleyimaging.com. Good Luck! Jim
Jan 16, 2013 | Kodak Carousel 4600 Slide Projector
The lever that drops the slides gets stuck in the 'up' position when the carousel is on the projector but it works fine when there is no carousel attached. When it gets stuck you have to take the carousel...
If you are using a 140 tray with older slides, that's very logical! Over time, slides develop a "side-to-side curve". Because the Carousel 140 tray stretches the design limits of the projector to be able to accurately return the slide to the tray, the slightest bend or "dog-ear"(the fraying of the corner of the slide) will cause exactly the problem you're having. If you have a Kodak 80-Slide tray, try it. Chances are that it will work fine. If it does work fine, then you have 2 options: 1. Move all your slides into Carousel 80 Trays.
2. Have your slides re-mounted (that is, have the paper mounts replaced).
I hope this helps !!
Feb 14, 2011 | Kodak Carousel 4600 Slide Projector
What is the correct carousel for a kodak 760 H projector?
A KODAK Carousel 760H is designed to be used with either KODAK 140 or KODAK 80 Slide Trays. The KODAK 80 Slide Tray has wider slide compartments, which tend to be more forgiving for older, slightly warped slides.
Oct 02, 2010 | Kodak Office Equipment & Supplies
I'm having a problem loading a tray onto my kodak carousel 4400 slide projector any solutions?
Jan 14, 2010 | Kodak Carousel 4400 Slide Projector
Trying to find a carousel that will fit Navitar model CP-300AF
I am pretty sure that the projectors modified, marketed & sold by Navitar were Kodak projector bodies & slide transports. Assuming this is the case, a Kodak 80 Tray should work just fine!
Aug 03, 2009 | Navitar 750-AF 35mm 80 Slides Rotary...
Open Questions:
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
