Question about JBL MR140
I have a JBL MR-140 radio and no power goes to it when plugged in power source.
Posted by Richard Brosseau on
Humphrey njoroge
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
Check the fuse if the fuse is good check if you have pluged the face well
Posted on Jun 15, 2019
1 Related Answer
Elliot
  • 108 Answers
SOURCE: JBL MR-4 CD doesn't eject
The unit probably doesn't think there is a CD inside. Possible doing a soft reset will fix this. Do so by powering the unit and putting a ball point or other pointed object into the reset button opening either on the face of the radio or behind the face. A hard reset can be done by disconnecting constant power from the unit for approximately 15 seconds.
If either of these methods fail, then your unit has a bad CD mechanism or more than 1 CD inside the player. In that case, the unit will have to be serviced by an electronics repair or a local stereo shop. This is a Marine radio, and if installed on a boat, this problem is not too uncommon. Moist air can cause damage to the unit as well as the bouncing on the water that boats do.
Posted on Aug 11, 2008
Hi, I bought a new JBL SCS 140 system with amp HK
Fuses blow when something is shorted. In this case it will be a semi-conductor of some kind. If the device uses IC for the main amplification then you are right to be worried!
The 158 amp is totally unsuitable for the JBL.
This is the specification of the JBL:
  • Recommended Amplifier Power 10 Watt
  • they are also 4 Ohm speakers.
  • 158 is: Output Impedance / Channel
    8 Ohm.
May 31, 2017 | JBL PB10 Subwoofer
Radio faceplate replacment
try a wreckers as they salvage a range of radios.
May 25, 2013 | JBL Car Audio & Video
I have a jbl mr17 radio and i want the clock to stay on
Clocks are usually wired into same circuit as your dome/interior lights, so they have constant power, regardless whether key is on or off.Should be able to find a wire to splice into around your fuse box.
Nov 01, 2011 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
How to connect aftermarket radio into 2002 toyota camry JBL radio (the standart wiring doesn't work).Thanks
Your aftermarket radio should have color-coded wires which identifies power, ground, speakers, etc. most depaetment stores carry a radio harness adapter kit. This will connect to your radio's exact color coded wires, and will plug right in to your factory's wiring plug. And don't forget electrical tape.
Aug 28, 2011 | 2006 Toyota Camry
I have a JBL MR 15 does this radio have a place in the back to plug in an ipod adapter. I think it is an Aux input RCA Jack The radio is on my boat and not near for me to look at it.
if it has aux input rca's, then go to an electronics or car audio shop and buy a "stereo rca to 3.5mm headphone jack adapter cable" This will then plug into the headphone jack on the ipod.
Jun 13, 2011 | JBL MR-15 CD Player
JBL MR-17.2 not recognizing Sirius satellite receiver.
I have the exact same issue. I have swapped with two identical MR17.2 radios and swapped out the sirius receiver. No change. I even bought a remote thinking I had to have a remote installed to get it to work...still no diff. Have you ever found a solution?
Jul 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
Radio locked, code needed
you have to call jbl and give them model and serial number may charge $25
Jan 04, 2009 | JBL MR-5 CD Player
JBL MR140 Logo
251 people viewed this question
Top JBL Car Audio & Video Experts
Marvin
Marvin
montehammons
Rocguy
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
