SOURCE: Garmin Edge 305/GSC10 Cadence and speed sensor
Had the same problem. Here is how I fixed it.
1. Changed the battery in the cadence sensor. (GSC10)
2. Turned on my garmin 305 edge outside to acquire satellites (probably not nec but did it anyway)
3. Pressed reset on the GSC10, saw red/green flash (what order?)
4. Here's the missing step: On the Edge unit, go to SYSTEM.
5. Scroll to bottom, choose ACCESSORIES.
6. On acc. page, go to bottom, under Cadence Sensor, to the option RESTART SCAN. Press That. Now your cadence and speed should work.
SOURCE: Bicycle computer not registering speed
On both the sensor stick (which goes on the fork) and the magnet (which goes on the spokes) there is a center line engraved on each. The centerlines on both have to cross each other at a distance of about 1/4" to register on the odometer.
SOURCE: The location of the speed sensor. How can I get to it?
1995 Jeep Grand Cherokee 4WD 5.2L MFI 8cyl
The Vehicle Speed Sensor is located in the Transmission / Transfer case.
For more details, can visit the Jeep ZJ Service and Repair Manual.
Good luck. (remember rated this help)
SOURCE: speed sensor location 97 plymouth neon
Not likely the speed sensor more likely to be the dash cluster common problem with neons.
SOURCE: cadence does not register on edge 705
This is probably a pairing problem. Device and cadence should be paired. Pairing is often lost when changing battery.
Pairing the Edge 305 and sensors
Once you have installed the Garmin Edge 305 and the
cadence sensor they need to be paired. As they communicate wirelessly
with each other the Edge needs to connect to each sensor before it can
receive input from it.
The initial pairing needs to be done away from other
wireless systems this allows the Edge to pick up the sensors it is
supposed to be monitoring. This is a little like black magic, but it
seems to work quite easily.
The cadence sensor has a small press contact which puts the sensor into pairing mode. The HRM just seemed to connect by itself.
Subsequent pairing is much faster as the Edge 305 seems
to remember which sensors it is paired with. If you have problems or
need to change one of the sensors then you can use a setup feature to
either turn the sensor off or to re-pair it.
