Question about Archos Audio Players & Recorders
I have an Archos 404 and it has always worked with my windows 10. It has quit Have no idea what to do. Don't know if it is the usb cord or what it charges but won't let me put it in window mode.
Posted by Sam Browning on
5 Related Answers
Ricky Johno
  • 4 Answers
SOURCE: ARCHOS 404.. new.. won't turn on or charge
Leave it to charge for 2 hours just in case there isn't enough power for it to boot up properly until it has an initial charge.
Posted on Jan 19, 2008
Anonymous
  • 3 Answers
SOURCE: archos 605 usb connection problem
its possible you could have picked up a virus that is making unauthorized changes to your pc. happened to me. had to reboot pc to original factory settings.
Posted on Jan 31, 2008
Anonymous
  • 3 Answers
SOURCE: Archos 604 wifi usb connection problem...
Okay, I just started reading your problem and started freaking out because it was happening to me and I suddenly thought that I would have to replace it. But luckily, my only problem was that I needed to prop-up my archos while it was plugged in. I would think that somewhere down the line, me and you have both knocked something loose in the connector. Luck to you, cheers.
Posted on Mar 24, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: Archos 404 hard drive
Cannot replace yourself - unfortunately
Posted on May 25, 2008
Anonymous
SOURCE: How Do I Go About Replacing The Battery Of My Archos 404 In The UK?
Hi! You should try this link: http://forum.archosfans.com/viewtopic.php?t=3906
Posted on Aug 29, 2008
Broken screen
i have the archos 404 with a crack screen need to get it fix
Jul 20, 2008 | Archos 404 Digital Media Player
My LCD screen on my Archos 404 broke i know where i can get a replace ment (newmp3technology.com) but i don't know how to fit it in to archos. can you help, thank you
1. get a LCD screen from newmp3technology.com
2. use a bit of card or credit card and slide it between the LCD screen and the front this removes the glue
3. remove four screws on the sides
4. remove the back
5. lift the battary and unplug
6. lift the hard drive
7. remove the two screws in the corners
8. now you can remove the front
9. lift the LCD screen so you can see the cables
10. slide the cable out of its housing
11. to put the new screen in follow numbers 10 to 3
when removing the glue or the front of the archos do not touch the LCD screen as now its not fixed it will brake
Jul 19, 2008 | Archos 404 Digital Media Player
Battery problem
I had the same problem and changed the battery on Monday. Works fine. There are just four small screws to remove.
Replacement battery can be found here:
http://newmp3technology.com/404-battery.htm. I used them and can confirm that the battery comes with the right connector for the Archos 404.
Took 10 minutes to replace it.
Good luck.
Jun 02, 2008 | Archos 404 Digital Media Player
Archos 404
Did you click menu button and enable usb on the Archos?
May 26, 2008 | Archos 404 Digital Media Player
Archos 404
Archos is not claiming compatibility with vista, even with their latest firmware upgrade - sorry
May 08, 2008 | Archos 404 Digital Media Player
Archos 404 does not work at all since using Archos Docking Adaptor
You should try to only chare your Archos only when it is completely dead and charge it fully then the battery will be regular
May 02, 2008 | Archos 404 Digital Media Player
Dec 24, 2007 | Archos 404 Digital Media Player
ARCHOS 404
how do i down load pictures ,music
Oct 16, 2007 | Archos 404 Digital Media Player
64 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
