Question about Frigidaire Kitchen Ranges
Frigidaire ples389ech free standing range buzzes when preheat or bake buttons pressed.
Posted by Terry Davis on
Terry
  • Frigidaire Master
  • 11,377 Answers
1 Related Answer
SOURCE: I have frigidaire gas free standing oven
If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
I cleaned the oven self clean, now the oven preheat feature won't turn on
I don't know what kind of range you have or if it is gas or electric. You may have to call a repairman.
May 25, 2015 | Kitchen Ranges
My Frigidiare model GLES388DSA will not bake or broil
Good Afternoon Friend,
I understand your Frigidaire range, model# GLES388DSA, will not bake or broil. I suggest resetting your range, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try preheating your oven. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Kitchen Ranges
How do you change a dual element control on a frigidaire Mod#PLES389ECH. I do not know how to take off the cover under the knob. My oven knobs is on the front of the oven not the back as indicated in...
I understand you are trying to change the dual element control on your Frigidaire range, model# PLES389ECH. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance and should be able to change the dual element control with ease. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire FEF366DC Electric Kitchen Range
Oven won't bake
Sounds like a connection issue to the control panel and the lower portion of the unit. Contact a professional to have the unit diagnosed unless you find the ohm reading to be off for either broil or bake element.
Dec 26, 2012 | Frigidaire FEF352 Electric Kitchen Range
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
I have frigidaire gas free standing oven range.When I press BAKE and set the temperature,the preheat and oven lights both lit on the display and I can see the ignitor red but no flame.
Nov 02, 2009 | Frigidaire FGF378AC Gas Kitchen Range
Require Electronic Oven Control Guide for a drop in/slide in electric range model Model CFES365EC Frigidaire range self cleaning free standing
the problem with the oven is that,when we start it to bake sumthing it turns of automatically after half and hour,and it doesnt bake anything...can you please help us with this problem...
Sep 16, 2009 | Frigidaire Ovens
Kitchen Ranges Logo
70 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
