If you need to remove the tail lite, brake lite and signal light harness start by removing the seat. Then disconnect the negative battery cable. Then detach the rear electrical harness connector. Then locate and follow the wires for the taillight and signal lights to the connector (8 pin) under the seat area and separate the connector. Then cut the cable tie strap holding the wiring harness to the frame and pull the harness through the fender opening. Then follow the conduit/harness back to the fender hole where the wiring exits the fender underside and enters the tail lite housing and backplate. This is not necessary for removal of the tail/brake lite assembly or the signal lie assemblies.
If you want to remove the tail/brake lite assembly remove the tail light lens and the with a small screwdriver depress the small tang in the tail lite four wire Multilock connector and remove the tail lite and then do the same and release the two wire signal light connectors one at a time from the tail lite base and remove the signal light connectors. These smaller two wire Multilock connectors are on the left and right sides of the base plate in the centre portions of the base plate where the 4 wire tail lite connector on the left side of the base plate is located and the wiring harness connector of the wires from the front of the bike to the base plate on the right side. The wires from the left and right signal lite assemblies go from these connection points on the base plate out through each side of the base plate and into the area under the back of the rear fender to each signal lite assembly. Then similarly release the Multilock connector of the harness from under the seat to the tail lite base. When you have disconnected the connectors from the base plate and have routed the wire harnesses out into the area under the fender you can release them from the wire clips at each side of the under fender areas. Then for each side remove the lamp support by unscrewing and removing the fastener and washer inside the rear fender, after which the lamp housing can be removed from the lamp support by pulling it and the wiring you disconnected from the tail lite base out through the lamp support. If you wish to release/remove the tail lite base undo the fastener and remove it.
Are you speaking in terms of playing reggae music? Listening to it? Moral questions? If you are asking as a musician, I see no problem with it, however there are some things you need to know and practice to be able to play it properly. Would like more detail about what you are asking :)
Not sure if you will find one... Process on toshibas is:
Pop top cover (sometimes also secured with a few screws on side or bottom of laptop) near monitor base above keyboard to access LCD cable and mount screws
Unplug cable and remove monitor mounting screws (Under plate, on back where cables plugin, and sometimes on bottom)
Take monitor (on flat surface) and remove screw covers with needle so you can put them back on later.
Remove all screws
Use plastic credit card and run around outside lip of screen case until removed
Remove LCD mounting screws
Remove LCD and inverter
Remove LCD brackets and inverter from panel
Replace panel and start working backwords.
Did you fix this problem? I have exactly the same model with exactly the same problem. I've checked the capacitors on the PSU board (as suggested in one of the responses above) and they all seem OK. If you fixed the problem, I'ld really like to know the solution. Many thanks.
dust and debris get under the plate; remove the fence from the base and the lock mechanism from the plate; flip saw over and remove the retaining nut from the spindle, the base should pull easily away from the plate.thoroughly clean the bottom of the plate and the top of the base and check for/remove any imperfections in either with emory cloth. use a mineral oil based lubricant when reassembling and be careful not to overtighten the retaining nut.blow out the base after use with an air gun and lube lightly after each day's use to avoid this in the future
The base is removed and turned 180 degrees and put back on phone notice the slide tabs are in correct position and can noe be hung by screws or a wall jack. Where the cord plugs in there is a breakout tab, that is the insert to hold the reciever on the phone when hung up.
You can take the front cover off of your programmable thermostat. Unscrew approximately 2 screws that attach the base plate of the thermostat to the wall. Look in the back of the base plate after removing it from the wall to see how the 2 or 3 different colored wires (ex: red, green, black) are hooked up. Make note of this. Remove the wires from the back of the base plate and attach the wires to the same posts that they were connected to on the original base plate you removed. I believe the posts on the back of the base plates are color coded. (Ex: attach green wire to where it says GRN on back of base plate).
Make sure the thermostat that you are replacing and the new thermostat are similiar in shape, otherwise you will have make repairs to cover up a space that may appear around the new thermostat.
