Question about Watches
Bottom of watch by second hand....what is symbol
Posted by Joan Curley on
Shawn Hudson
    Sergeant:
  • 190 Answers
You've probably heard people go on and on about the "sweep" or talk about how top quality watches don't make that tell-tale "tick-tock." For all intents and purposes, these people are right. When you pick up a Cartier or Chopard, the tiny hand measuring the passage of seconds glides effortlessly, like a toothless hockey player. In actuality, all wristwatches tick-tock. However, in a true quality watch, the internal mechanism (the movement) is so finely tuned and so well constructed, that these ticks happen as often as nine times a second, producing a flawless sweep. This is the difference between a five-dollar movement and a movement costing hundreds of dollars.
Posted on May 13, 2018
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    My watch is stuck on military time somehow. I would like to know how to change it back to normal time. My watch is a Armitron Alarm/Chrono WR 165 sports watch. The number on the back is 45/6915. Thanks for...
    Welcome to Fixya,
    The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
    1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
    2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
    3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
    4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
    5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
    6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
    I hope this will help you.
    Thank you for usinf Fixya.
    Feb 21, 2011 | Watches
    How to get the second hand to move
    If you are referring to the large orange colored hand, it is NOT the second hand. It is the hand of the depth indicator when the watch is used for diving. Or it is the timer hand when the watch is used as a stop-watch. The second hand is actually on the bottom sub-dial.
    Jun 15, 2010 | Citizen Eco-Drive Aqualand BJ2004-08E...
    Second hand doesnt move. The ''stop watch'' second hand moves instead of the ''main'' second hand. also the stopwatch feature doesn't work. My watch is a Fossil Blue Titanium model TI-5071
    Sounds like a job for Fossil!
    Go to their web site "www.fossil.com" and at the bottom of their page is a menu which includes "store locator".
    Feb 24, 2010 | Watches
    My Stauer Atomic won't stay connected to time signal
    These watches only need to see a signal several times a day, not necessarily continuously.
    If it keeps good time, don't worry about it.
    Jan 05, 2010 | Watches
    Large second hand not running, Stop Watch function?
    Hey, it sounds like your watch is just fine! A nice watch to inherit.
    The small second hand on the sub-dial is your normal second hand.
    The large second hand is the second timer for your chronograph feature.
    It should only move when you hit the side buttons. One of them (usually the top plunger/ button) will start the Chrono timer and then hitting it again will stop it. The bottom button should reset the hand to the 12 o'clock/ zero marker.
    If the large hand is not functioning at all then there may be something wrong with the watch; perhaps the buttons are not making full contact within the watch or the hand may be stuck and need repair.
    Hope this answers your questions. Post more questions if need be.
    Congrats on your new watch.
    Oct 21, 2009 | Festina Road Warrior F16273/4 Watch for...
    Need to know how to operate Cartier Tank Francaise Chronography W
    The top button is for chronograph function and puts the chronograph seconds hand in motion. The bottom button is for resetting chronograph seconds hand to zero.
    Do as follows:
    1) push the top button once- seconds hand starts moving,
    2) push the top button once more- seconds hand stops,
    3) push the bottom button once- seconds hand returns to zero.
    You can repeat as many times as you like- seconds hand will allways start the countdown from zero.
    Depending on what movement your watch has(mechanical or quartz), there can be more variations, but the basics are as described.
    If you need more info, supply full info of your watch(make, model, numbers, etc.), please.
    Do not forget to rate, please.
    Jan 10, 2009 | Cartier Tank Americaine W2601156 Wrist...
    Festina 16177 / 8- Tour de France 2005 - second hand not moving
    The large sweep hand is not the second hand,it is the 1,100th sec hand on chrono.The second hand during time mode is the small dial at the bottom which should be going round
    Jul 22, 2008 | Festina 16177 3 Watch
    Watches Logo
    Top Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Bruce Robin
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
